Junior Member
![]() Join Date: Aug 2009
power steering pump bracket
I have a 69 C10 with a 350 sbc and a short water pump. I need to find a factory power steering pump bracket that will allow my pulleys to line up. I am using a 3 groove pulley on the crank. I bought an aftermarket one from jegs but it doesnt line up. Any help would be great! Thanks!
'69 SWB, 396BBC, M21-4 speed |
Re: power steering pump bracket
Not sure, but bump might help with answers
1969 Chevy c20(Miss Hackjob) |
#3 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
I'm in the same shape, thought about going to a serpintine setup [I have several laying around] my problem is I have no holes in my heads as I have a 327 form I belive to be a 68 but was told that it is a crate motor. I bought this truck from the local school dist [70 swb] and the bus shop super drove it and had a stack of 327's in crates to replace motors in the buses when they went out. About two years before he retired he had the bus shop put in the last of the crate stack they had leaving me the truck with supposedly only a couple thousand miles on it
#5 | |
Sierra Grande Club
Allen Grove, if you aren't doing a factory restore. Awesome products, made in us, good ol kansas! Picked on up for my short pump and worked like a charm!
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Try this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=201500
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
My advice would be to find a stock, unmolested setup from a 67-72 truck that somebody is parting and get both the crank and water pump pulleys. If you think your alternator bracket and PS pump are wrong get those too while you can.
I never could get stuff to line up until I did that. The parts board here is a good source for a matching set. Posted via Mobile Device
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
