Old 12-22-2011, 09:56 PM   #1
biohazardbill
Burban Rear Wheel Wells, Removal
Anyone have any tips/tricks for removing these and preserving them? On my fleetside they completely unbolted however on the burb it seems as though this is not the case.
Any help appreciated.
biohazardbill is offline   Reply With Quote
Old 12-23-2011, 08:32 AM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Burban Rear Wheel Wells, Removal
If you go back through my build when i cut mine out there was bolts around the bottom on the inside but i cut over the top on the inside and also inside where the wheel is you have to cut on the backside of the wheel opening take your time there is a little work to do it right.
gostranger is offline   Reply With Quote
Old 12-23-2011, 09:26 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I believe they are spot welded to the fender lip. I trimmed mine to fit my 295's in the rear. Havent completely removed them, though.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
