Old 12-22-2011, 10:10 PM   #1
mockingbird
Where to look for rust on 1986 chevy
I am going to be looking at an 86 1/2 ton 4x4 chevy and was wondering where to look for problem rust areas. I know that the cab corners, rocker panels,fenders and bed sides rust. But was wanting to know where else these trucks rust. Any help would be appreciated.
mockingbird is offline   Reply With Quote
Old 12-22-2011, 10:14 PM   #2
Goldfinger
Goldfinger's Avatar
Re: Where to look for rust on 1986 chevy
Bring a magnet. The fender wells the floors the cab corner. check the wiring. the tailgates rust bad. knock around the sheet metal if it goes from hollow to a solid sound it might have bondo.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-22-2011, 10:29 PM   #3
donut
donut's Avatar
Door bottoms, top of the gas tank (bottom if it has a shield on it) cowl, spring mounts....
Anyplace water, mud, dirt, salt, can sit.
If you start finding rust, you WILL find a lot more the deeper you get.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-22-2011, 11:03 PM   #4
rpmerf
rpmerf's Avatar
be sure to look at brake and fuel lines
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-23-2011, 12:51 AM   #5
Mr. 250r
Mr. 250r's Avatar
Everywhere lol, axle housing from a rusty environment - inner fender wells on front, core support, cab seal on fire wall behind motor, all of cab/bed, frame, all exhaust and hangars etc might as well check it all I've seen rust in every spot and not just a little
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 12-23-2011, 12:55 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Look at the firewall seam that is behind the engine. This seam is where the cowl meets the actual firewall. If there is no bubbling at this seam, then the truck has not seen too much rain and the seam sealer that is inside the cowl is still good. Also look at the rear fenders above the wheel wells and the area just behind the front fenderwells, where the large bolt is holding the fenderwell to the cab.
Frank
piecesparts is offline   Reply With Quote
Old 12-23-2011, 08:56 AM   #7
ont_guy_38
ont_guy_38's Avatar
Look at the frame , mostly the rear half
ont_guy_38 is offline   Reply With Quote
Old 12-23-2011, 09:38 AM   #8
madcow75
madcow75's Avatar
Yes rear of the frame, especially at the front of the rear leaf springs. Dirt and salt get trapped and rot the frames out.
madcow75 is offline   Reply With Quote
Old 12-23-2011, 09:53 AM   #9
xrcr
Agree with everything previously posted. Would say that the Firewall is the worst to fix. Look at the A-pillars that would run a close second or tie. Everything else is fixable just varying degrees of a PITA.
Just my opinion, I could be wrong.
xrcr
xrcr is offline   Reply With Quote
Old 12-23-2011, 11:57 AM   #10
77shortstep
77shortstep's Avatar
everywhere
77 CHEVY - SHORT BED STEP SIDE 2WD
02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT
77shortstep is offline   Reply With Quote
Old 12-23-2011, 04:35 PM   #11
notyo_cheez
One of the hidden areas is the pinch welded seams under the front and rear window gaskets, you can't tell unless you remove the windows. And there aren't any aftermarket patch panels for them either. Fortunately my project came with the rear window out and the damage was obvious...
My donor cab had some rust on the firewall seam too. The seam sealant shrank after 25 years in the south Texas sun, water and pine needles settled in and damage was done. I just ground out as much as I could and crammed some fiberglass filler in it, called it done. It won't win any beauty contests, but so what.
notyo_cheez is offline   Reply With Quote
