Old 12-22-2011, 10:32 PM   #1
Blue Heeler
Blue Heeler's Avatar
2"Drop spindle
Hey guys getting ready to put 2" drop spindles on the blue heeler, is there any
problems running 15" rallys? any rubbing or clearance problems i should look for? thanks and have a Merry Christmas.
Blue Heeler is offline   Reply With Quote
Old 12-23-2011, 02:54 PM   #2
brawley
Easy Does It
brawley's Avatar
Re: 2"Drop spindle
I am using 15" rallys with 2 1/2 " drop spindles with no problems. I think if you change over to large disc brake rotors there could be issues.
brawley is offline   Reply With Quote
Old 12-23-2011, 03:43 PM   #3
doobiebro
doobiebro's Avatar
Re: 2"Drop spindle
Blue heeler I ran 2 1/2 drop spindles with a disc brake conversion on my truck and ran into problems with only the stock 15 inch wheels...they rubbed on the calipers. Are you installing disc brakes and running original style 60s rims or the rallys from later years?
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 12-23-2011, 04:25 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 2"Drop spindle
I guess those 2" are the modular spindles?
I believe they are made specifically so you can run bigger wheels.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-23-2011, 07:08 PM   #5
Blue Heeler
Re: 2"Drop spindle
I'm running some 15x7 rallys
Old 12-23-2011, 07:09 PM   #6
Blue Heeler
Re: 2"Drop spindle
And yes those are modular spindles from cpp
Old 12-23-2011, 08:26 PM   #7
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Re: 2"Drop spindle
i just installed my 2.5 spindles with disc brakes. im running 15 in steelies. the calipers rub so i need to install 1/4 spacers hopefully it works.. i have the stock style drop spindles not modular..
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 12-23-2011, 08:51 PM   #8
SCOTI
SCOTI's Avatar
Re: 2"Drop spindle
Disc brake spec steel wheels should work w/o issue. Early drum brake wheels will have caliper clearance issues & will require spacing the wheel out.
You shouldn't have any problems w/a stock 15" wheel. Aftermarket wheels w/agressive back-spacing might require some clearancing @ the lower a-arm lip (stockers usually only run when close to full lock).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-24-2011, 12:20 AM   #9
doobiebro
doobiebro's Avatar
Re: 2"Drop spindle
Mad Rods I don't think 1/4 spacers are not enough. ScotI is correct on the early drum brake wheels. I spent over 2 years finding 1 wheel to match the 3 remaining to have the complete set on my truck to end up selling them. I ran into the same problem and the only solution was to buy a set of new steelie wheels (bare metal) from Summit for about $49.00 bucks same wheels Wheel Vintiques make but cheaper through Summit. Heres sum pics of the original wheel that did not work and new wheel.
Old 12-24-2011, 01:56 AM   #10
Slow Build
Slow Build's Avatar
Re: 2"Drop spindle
I asked CPPJEFF that question a while back but about the 8" rally wheels. He said they would work with the modulars.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 12-24-2011, 11:57 AM   #11
Blue Heeler
Re: 2"Drop spindle
I'm just running everything stock as far as rotors and calipers, i would just hate to do all this work and run into problems. thanks guy for all you help.
Old 12-24-2011, 01:46 PM   #12
MalibuKasey
Artist
MalibuKasey's Avatar
Re: 2"Drop spindle
so heres what I did... I wanted stock steelies on my truck... So theres to ways to go about this with out spending the extra money for the modules. 73-87 chevy work vans are 6 lug and have a 15x6 wheel... thats what Im running on the front with NO problems since they had disks as well. For the Back I found a 3/4 military truck from the same years.. they came with a 15x8 steelie from the factory. As for your rallies question... depending on the year they should work just fine!!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 12-24-2011, 05:13 PM   #13
stealth_weapons
Re: 2"Drop spindle
here is what i have. 2 1/5in POL drop spindles with 12in rotors on 15in wheels;
clearance;
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 09-09-2014, 08:04 PM   #14
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 2"Drop spindle
clearance;
Looking at the above photos, it appears that if the caliper mounting arms on the spindles clear, the calipers will also clear. Is that correct?
Here is a standard spindle I mocked up to my 15" wheels (no drop).
66 C20 Service Truck:
Old 09-09-2014, 10:28 PM   #15
LostMy65
LostMy65's Avatar
Re: 2"Drop spindle
Does this mean I have a 3-1/2" backspace?
Old 09-10-2014, 03:28 PM   #16
LostMy65
LostMy65's Avatar
Re: 2"Drop spindle
Okay, I went ahead and bought some stock calipers to see if they clear, and yes, they do.
The calipers actually have more clearance than the spindle's caliper arms/ears.
So, I guess if a standard spindle clears, can I assume a modular 2" drop spindle will also clear?
Old 09-10-2014, 04:27 PM   #17
forestb
forestb's Avatar
Re: 2"Drop spindle
I got a set of CPP modular drop spindles and thay rubbed on my 15X7 rally wheals. I can't quite remember if it was rubbing on the wheal or the weights clipped on to the rim of the wheel. I ended up getting 17 inch wheals so I can't check. You should be able to grind down on the spindle if it does rub.
forestb is offline   Reply With Quote
Old 09-10-2014, 05:21 PM   #18
davbowen
davbowen's Avatar
Re: 2"Drop spindle
it all comes down to back spacing of the wheel. 4" back spacing would be the max you want with 15" wheels. i bought a complete kit with 2 1/2 drop spindles from ECE and it all worked with my 4" back space wheels as they said it would. i did grind the nub off the tie rod arm for more clearance to the weights. i have 73-8? 4x4 6 lug rally wheels. i believe those 15x7 are either 4" or a little more. lostmy65 yes thats 3 1/2" back spacing and should work.
davbowen is offline   Reply With Quote
