Old 12-23-2011, 01:41 AM   #1
Deadman70
How to keep my Battery and Engine Secure?
Hey Guys need a little Help.
I just got back from vacation and I walk out to my truck to start it up and find that someone has flipped the hood and stolen my battery (just after I replaced it and installed a new battery holder, etc). A couple of questions.
1. Is there a way to lock the hood? A part or some kind of Trick?
2. If not is there a way to secure that battery so its next to impossible to pull out.
I would rather secure the hood since I have started putting money into this to restore it. I have A 1973 K20.
I was thinking about cutting some razer blades and putting them right where you life the handle... but I would probably get sued if the guy lost his fingers.
Deadman70 is offline   Reply With Quote
Old 12-23-2011, 02:30 AM   #2
rcbildr
rcbildr's Avatar
Re: How to keep my Battery and Engine Secure?
Was the battery bolted down? Easiest thing to do is remove the battery and put it in your shop/garage. I do that on all my parked/project vehicles if I know they are going to sit for a while...have a lot of tweeker speed freaks roaming around where I live. When I was in highschool a friend of mine used 2 pieces of chain and a padlock to lock the hood on his chevelle. IIRC one piece was bolted to the hood and the lower piece was bolted somewhere on the lower part of the core support.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 12-23-2011, 02:39 AM   #3
Blue72slab
There are a couple of options that I have heard of. There have been a few discussions about it over on Team Camaro. Keeping people out of the engine compartment is also one of the best ways of making it hard to steal your truck as well. The easiest method is chain the hood closed and lock it. The other method is get a universal cable that you can install that won't allow the hood latch to move when engaged and it locks inside the cab.
Larry
1972 Chevy C20 Custom Camper
1968 Chevy Camaro RS
1980 GMC K5 Sierra Classic
Blue72slab is offline   Reply With Quote
Old 12-23-2011, 08:09 AM   #4
xrcr
I used coated cable and a padlock on my camaro, then I moved...
xrcr is offline   Reply With Quote
Old 12-23-2011, 08:45 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
chain and lock not pretty but it works
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-23-2011, 09:18 AM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
if you dont mind hood pins stick'n outa the hood you can put lock's on them, also you can get hood pins that are lock's but there more exspensive.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-23-2011, 10:39 AM   #7
muthstryker
muthstryker's Avatar
http://hoodpins.net/cart/index.php?m...&products_id=3
Matt
muthstryker is offline   Reply With Quote
Old 12-23-2011, 10:48 AM   #8
RandyP
Getting Old; Going Broke
RandyP's Avatar
I remember back in the 80's a lot of the car alarms came with a hood lock. It was basically a bracket you bolted to the underside of the hood that had an eyelet in it. When closed and the alarm was set, a rod would engage and go through the eyelet in the bracket making it impossible for the hood to raise. I seen them go as far as to install it where the rod actually went through the latch where they had drilled a hole, making it where the latch could not release while it was engaged.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 12-23-2011, 05:49 PM   #9
Deadman70
Red face Re: How to keep my Battery and Engine Secure?
Thank guys,
I think I will have to go with some type of cable or lock. I had the battery in a tray with one of those brackets I got of LMC. So it was kind of in there but nothing that you couldn't twist and get off. At least the jerk left those in there when he took it. I like the Hood pins but the hood is one of the things that is going to need to get replaced so don't want to head that route.
Removing the battery would be great however, I live in a town home so I half to move the Truck when I want to work on it. So its not some place I can store it. However, at least they can't steal the whole truck.
I had another car that I had parked in the same spot and some guy busted the window and stole my cell phone. I actually called the guy and he answered. I told him there was a gps chip in the phone and that cops where coming to get him,lol. Of course they where not, but I did feel better.
Thank guys, Have a great Christmas.
Deadman
Old 12-23-2011, 07:35 PM   #10
john_p
a simple blinking led on the dash next to a web cam may help.. wire a switch that pulls a locking relay and just holds the horn down.. might scare someone off.. sorry for your lose, guess i am lucky living in the country..
john_p is offline   Reply With Quote
Old 12-24-2011, 12:52 AM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
surprised anybody these days can find the hood latch up front these days...
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-24-2011, 08:04 AM   #12
Goldfinger
Goldfinger's Avatar
hook a solar electric fence to it?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-24-2011, 08:21 AM   #13
BigBlocksRule
Bicycle lock, coated cable is the best. If they can't lift the hood, they can't steal your battery.
I've had 'em steal carburetors, starters and radiators. I now have everything locked up in a chain link fence with barbed wire around the top.
FYI, if you have an Interstate Batteries distributor close, buy "BLEM" batteries from them. They're about $40, I've got 'em in everything I own and have never had an issue with 'em.
BigBlocksRule is offline   Reply With Quote
Old 12-24-2011, 01:37 PM   #14
njlimbaugh
It's possible to build a locking pin that's pulled with a regular choke cable to open the hood. Electric locks are OK, but if your battery goes down, how the heck do you open the thing?
njlimbaugh is offline   Reply With Quote
Old 12-24-2011, 01:40 PM   #15
Sillyoldman
#16876
Sillyoldman's Avatar
I dug this up for you. Hope it helps http://67-72chevytrucks.com/vboard/s...d.php?t=407682
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-24-2011, 01:47 PM   #16
Dunenutt
Newbee
Dunenutt's Avatar
I used one of these on my 69. It's a little pain to get it set up, but works like a charm.
Amazon.com: Megatronix - HL6 - 6 Foot Mechanical... Amazon.com: Megatronix - HL6 - 6 Foot Mechanical...
Dunenutt is offline   Reply With Quote
Old 12-24-2011, 01:52 PM   #17
Dunenutt
Newbee
Dunenutt's Avatar
OOPS, link bad. You can buy them at Amazon.
http://www.megatronixusa.com/product...tems/hl/hl.htm
Old 12-28-2011, 05:32 PM   #18
Deadman70
Hey A lot of good Ideas, One thing that didn't seem to come up was are there any good aftermarket alarms that are not to hard to put on that would protect the truck in General. Looking for Recommendations?
Old 12-29-2011, 09:04 AM   #19
space wrangler
maybe one of these to keep the battery secure. ..you can lock down the top.
http://www.artecindustries.com/Batte...nts_c_134.html
space wrangler is offline   Reply With Quote
Old 12-29-2011, 09:51 AM   #20
tucsonjwt
On my old beater 73 I cut a hole in the hood support on the front edge and ran a coated chain through it with a padlock bolted through the bumper bracket - very crude but the hood had the typical "Chevy hood crunch" of that era and the chain helped keep the hood down. I like the padlocks through a bracket installed in the latch area in the other thread noted above. I would prefer the factory inside the cab cable and hood latch lock if you can make it work.
tucsonjwt is offline   Reply With Quote
