Brake Light stays on ???????????
On my 72 the brake light stays on. I have a good break peddle and the e brake works good also. Why is the light on??
Active Member
![]() Join Date: Jul 2007
Re: Break Light stays on ???????????
Check the switch above the brake pedal under the dash. If you disconnect it and the light goes off, the switch is probably bad or not adjusted properly.
Make sure that the E-brake pedal is all the way up. Next the brake proportionig valve has a plungerin it that senses difference in the valve . That valve has a tendency to get stuck in one position causing the lamp
Re: Brake Light stays on ???????????
THERE IS NO BRAKE LIGHT WHATSOEVER FOR EMERGENCY BRAKE
if your dash brake light is on there is a problem with your proportioning system
Active Member
Oops. I didn't notice that the "light" was singular. Disregard my post above.
Also check fluid level in m.c. |
Thanks Guys
Does anyone have a pic of the pin in the normal position in the proportioning valve? My light came on after bleeding my brakes and I have re-bled them. The air is all out but my brake light is staying on.
Shop manual has a procedure for bleeding that includes using a special tool to keep the proportioning valve in the correct position.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
is the wire plugged in to the mc?
sorry i meant the valve
Shortbed club member
You most likely have a leak somewhere.
When you lose pressure in 1 system (front or rear) the proportioning valve will close off that system. So you will still have a firm pedal but you will only be using front brakes or rear breaks. I would guess its your back brakes that are leaking, because you would notice not having front brakes.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
