![]() Join Date: Sep 2006
serpentine braces
Hey, I'm using the serpentine set up off a '92 on my '68 project. I can't figure out how these braces go. Can someone snap a pic of them on the truck so I can see? Thanks.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
Re: serpentine braces
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
Hey, that helps a bunch. Thanks.
Well, I think I can make the one that goes behind the alternator work, but the one that goes straight back from the compressor won't work with my edelbrock intake. Maybe I can modify it to make it work. We'll see.
Do you know where I can get an intake bolt with the upper threaded part to attach that brace to?
You're welcome!
I would go to the local U-Pull-It the get the studs you need, especially if I can put together a shopping list. If I needed no other parts I would try the dealer for the studs.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 12-23-2011 at 04:48 PM. Reason: add more |
Yeah, my pull a part is a little ways away, so I try to get a little bit of a list together before I head down there. Thanks.
| Bookmarks |
