Old 12-23-2011, 02:18 PM   #1
lucifer
lucifer's Avatar
Induction upgrade What do you think
Just finished istalling a TPI injection on my 64 283. Yup kept the original engine (tired of carb ) and put the 1986 Tuned Port Injection unit in place of the carb. Really brough that 283 to life!!
What do you think?????????
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 12-23-2011, 02:23 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Induction upgrade What do you think
That is a really sweet set-up! You are man after my own heart. I too like to make only bolt-on changes with as much original equipment as possible, that way in the future if I or someone else wanted a factory correct restoration, there will have been no modifications.
Nice job!
Old 12-23-2011, 02:29 PM   #3
csa daddy
csa daddy's Avatar
Have you checked out fuel mileage with that setup it looks pretty cool. What did you do swap heads an intake system to make it work
csa daddy is offline   Reply With Quote
Old 12-23-2011, 02:36 PM   #4
jimmydean
jimmydean's Avatar
That looks awesome! I've been eyeballing a C4 to rob the engine out of.
i would also like to know what all you had to swap to make it work and what sort of mileage you are getting.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-23-2011, 02:40 PM   #5
lucifer
lucifer's Avatar
No need to change the heads. The 283 heads have small combustion chambers and any later model head could end up with big compression loss.
The new intake bolts right on.
No mileage numbers yet...will advise when I get some real data
Old 12-23-2011, 02:41 PM   #6
brawley
Easy Does It
brawley's Avatar
looks good ! was it hard to wire everything up?
brawley is offline   Reply With Quote
Old 12-23-2011, 02:45 PM   #7
lucifer
lucifer's Avatar
Cool Re: Induction upgrade What do you think
Its actually a pretty simple swap. The key is haveing all the TPI sensors and wiring. I used a set up off a 1986 Camaro, went through the wiring and deleted wiring that was not needed. There is lots of info out there on TPi swapping and wiring so that was no big deal. I had a guy in Ca burn me a new chip ( 70.00 bucks) to delet the VATS and some other functions. You will need a high pressure fuel pump and I used an external Bosch unit, run some new lines with a return. Like I said there tons of info out there. Be glad to answer any speciific questions though.
regards
Old 12-23-2011, 02:54 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
That looks great. I don’t think I’ve ever seen this done on a 283 before. Personally I’m too old school to have the enthusiasm to tackle a swap like this on my own truck, but you sure can’t beat electronic injection for efficiency and reliability. And that tubular intake certainly provides a performance image. Nice job!
Old 12-23-2011, 04:44 PM   #9
1963c-10
1963c-10's Avatar
The engine looks great...you can definitely see all the work that has gone into it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-23-2011, 04:51 PM   #10
Pop's C-10
Pop's C-10's Avatar
Nice set up.. i love 283's...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-23-2011, 05:15 PM   #11
csa daddy
csa daddy's Avatar
So as long as you use an intake before 87 this will work correct . Cause I thought the heads on 87 up have different intake bolts either straight or angled if I remember correct. When you get some mileage numbers let me know cause I'm definelty interested to see how much it will help
Old 12-23-2011, 05:39 PM   #12
lucifer
lucifer's Avatar
You can use the later intake but you would have to open up the four center bolt holes to make it work. I have actually done that in the past and it works fine.
I will post mileage numbers when I get some miles on it.
regards
Old 12-24-2011, 12:34 AM   #13
doobiebro
doobiebro's Avatar
Lucifer I think that is awesome.....I myself love the 283 (For Life)...I had one on my 62 and now on my 60....here is sum pics old skool 283 block with a early 90s twist.
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 12-24-2011, 01:17 AM   #14
Rich 5150 69
Rich 5150 69's Avatar
Great job Lucifer...and get back to us with the MPG`s when you can stop driving long enough...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-24-2011, 09:31 AM   #15
lucifer
lucifer's Avatar
Doobiebro That's agreat job! 283's are iconic and will live forever!!
Old 12-24-2011, 09:46 AM   #16
duallyjams
duallyjams's Avatar
That's a nice n clean set up.What was the mpg with the carb ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-24-2011, 11:11 AM   #17
'63GENIII
'63GENIII's Avatar
I love the factory look that you're set up has. Even though the 396 in mine isn't original, I often thought about swapping the FI parts from the '97 454 that I have onto it, but I think it's more involved than just swapping the intake. Your project is motivation for me to get on with my swap though. Great work there! BTW How are the morning cold starts? Pretty much turn key?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-24-2011, 11:16 AM   #18
joedoh
joedoh's Avatar
love it!! efi is the best
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-24-2011, 05:54 PM   #19
lucifer
lucifer's Avatar
Cold starts are a non issue EFI and Florida LOL
Old 12-27-2011, 01:42 AM   #20
enick72
enick72's Avatar
Love it. I have a L98 Tuned Port I just finished going though and ready to put in. I'm sure I'll have some questions. I think I have everything that I need as I have read everything that I can find in books and on the web about TPI.
What have you used for a throttle cable and pedal. I had planned on using new style chevy truck pedal and cable but was unsure about the length.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 12-27-2011, 07:34 AM   #21
lucifer
lucifer's Avatar
I used the late model truck pedal and bought an aftermarket cable from Mr Gasket # 5657, it has all the right stuff.
Old 12-28-2011, 02:14 PM   #22
enick72
enick72's Avatar
Thanks, just ordered, now I just have to go get a pedal.
55 Chevy 1st series
Old 04-05-2012, 11:36 PM   #23
1enick72
1enick72's Avatar
regards
How did you end up running your return line? Are you using your original tank? I cheated and ran my return line into the supply line before the pump and filter. My issue now is after driving about 6-8 miles or idle for 10-15 minutes I start loosing fuel pressure. The strange thing is that if I put my foot to the floor it spits for a bit and then the pressure comes back and it goes like crazy but goes back down. When it is cold it runs perfect. I have started running my return line back to the tank hoping that this takes care of the issue.
1enick72 is offline   Reply With Quote
Old 04-06-2012, 01:05 AM   #24
Captainfab
60-66 Nut
How you have your return line is causing your problem. You are introducing warm, aireated fuel back directly into the fuel feed. Your return line needs to run back into the tank, as far away as possible from the pickup tube. This gives the fuel time to cool back down, and for any air in the fuel to disapate.
Old 04-06-2012, 01:06 AM   #25
Captainfab
60-66 Nut
Have you been able to calculate any mileage numbers yet?
regards
