Old 12-23-2011, 05:26 PM   #1
66shortwide
Master Cylinder size question
Any brake experts out there? Wanting to run manual brakes on my truck and have a couple of master cylinder questions. I have c4 corvette brakes front and rear(twin piston front calipers, single piston rear calipers) - so, what size master should i be looking for? 1"? If i go with a two master cylinder set up, should the front and back be the same size or different?
Really leaning toward the 2 master set up with the adjustable balance bar from wilwood on a 180 degree pedal set up so the firewall stays clean.
Trent
12 Cadillac CTS-V
07 Sierra HD 4x4 Duramax
66 C10 Short Wide
63 Chevy II(nova)
66shortwide is offline   Reply With Quote
Old 12-25-2011, 10:03 AM   #2
bama63
bama63's Avatar
Re: Master Cylinder size question
use the 70-75 corvette master 1" for manual brakes 1 1/8" for power brakes, i used the manual set up and it works great, now i run the wilwood super lites on my dirt racer with a 2 master both in 3/4" with 3/16 line all around and stops on a dime with little pedal effort
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
