Old 12-23-2011, 05:28 PM   #1
JJAB
One more time 317 vs. L92
Okay guys, I know this has been discussed and I also know that there are a million variables that are to be considered. The sad part about this is that I have not made my unltimate decision on what vehicle I am putting this in, but here goes.
I am trying to decide between ported 317 castings vs. stock l92 plus ls3 intake. My goal is to make 350 to 375 RWHP. The mill is a LQ9. All other things considered are the vehicle will have 3.73's, headers, it will stay fuel injected, 2200 to 2500 stall. I have a cam laying around that spes out at 218/228 @.050 and .525/.525 lift @.050.
JJAB is offline   Reply With Quote
Old 12-23-2011, 07:05 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: One more time 317 vs. L92
A stock LQ9, with a mild cam, headers and good tune, should have no problem making 375 RWHP I would think.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-24-2011, 11:59 PM   #3
Shon
your goals are low if you are looking at ported heads in either variation. I have several almost 400 to the wheels with just a cam in 346s/LS1s and I have some almost 500s with LS3 heads/cam/LS2.
I am a bigger fan of the cathedral heads if you going for MPH at the track but if you just want to make power it can be done with either set. I have seen cathedral heads run quicker at the track in comparison to the retangular ports and I am not sure if thats a mismatch of cam/heads or just better air flow from cathedrals.
I have a customer with a 23x/25x cam with stock LS3 heads/intake making nearly 500. He also has a 01 Z28 that makes almost 400 with just a cam.
The retangular heads are 'cheap' but there is more to it, you have rocker arms to get, intake to get too. so the cost goes up.
And that cam you have would be better suited for the cathedrals, the I/E split is not enough for the retangular heads from what i have seen, and if you want to sale that cam let me know, we love that cam...it makes great torque and helps with our 'tow' packages.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-25-2011, 02:10 AM   #4
clinebarger
A well tuned STOCK LQ9/4L65E will make those numbers.
clinebarger is offline   Reply With Quote
Old 12-25-2011, 10:21 AM   #5
JJAB
Thanks guys for your input. Your information has helped me make my decision.
Old 12-25-2011, 11:42 PM   #6
softballnrd27
Always a work in progress
softballnrd27's Avatar
No reason to port or change the 317s, get a good valve job and you should very easily make your power goals. If you want a little more power, get a little bit more cam.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-26-2011, 02:07 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
porting the 317's won't hurt, a little more flow is always a good thing
I just wouldn't mill them or do anything to raise compression any more on an lq9
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2011, 07:29 PM   #8
mooseknuckles
mooseknuckles's Avatar
http://www.carcraft.com/projectbuild...k/viewall.html
mooseknuckles is offline   Reply With Quote
