Old 12-23-2011, 10:46 PM   #1
68350
68350's Avatar
Need some starting help...
So I just installed a standard column in my 79 GMC. It was once converted to a 4 speed from an automatic. I got everything all hooked up and what not. Went to start it and it has full power except it doesn't turn over. Lights, buzzers, radio and everything works as it should, just doesn't start. No clicking or anything on the starter. Any help as to what wires to check for power or ? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-23-2011, 11:31 PM   #2
old yelr
Re: Need some starting help...
Neutral safety switch might need to be adjusted.
old yelr is offline   Reply With Quote
Old 12-28-2011, 10:10 AM   #3
dmcclanahan
I found the best way to get a good look at the wires that run to the steering column is to drop the column. Now what wire is it? IT'S the purple/white one that runs the power to the starter switch (that is mounted to the column). I run trace it from there back to the starter to make shire that its connected or not bear.
dmcclanahan is offline   Reply With Quote
