Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-23-2011, 11:32 PM   #1
kennyhammond
is this a good cam for rebuild???
is this a good cam for my truck its a 81 c10 and the motor is a 98 vortec motor..... all stock
EFI Hyd Roller Cam - Chevrolet 5.0-5.7L 279/287
Product Description
More details coming soon!
Hydraulic roller, good idle. Street performance. Improved mid-range torque and horsepower.
•Advertised Duration (Int/Exh): 279/287
•Duration @ .050 (Int/Exh): 213/219
•Gross Valve Lift (Int/Exh): .447/.471
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range:1500-5500
•Includes: Cam Only
Part Number: 54760LUN
Jobber Price: $337.16
Cam Spec Card Print
kennyhammond is offline   Reply With Quote
Old 12-23-2011, 11:33 PM   #2
kennyhammond
Re: is this a good cam for rebuild???
its a cruise around truck and i am puting a rpm intake with 600 cfm carb
Old 12-24-2011, 12:25 AM   #3
Captainfab
60-66 Nut
Yes, that one should work just fine. Although, you don't have to use a EFI friendly cam since you are converting to a carb. I don't think you'll get the sound you are after from this cam.
Old 12-24-2011, 12:41 AM   #4
kennyhammond
Yeah I wasn't to set on a muscle car sound right now....just some good usable horsepower .... I don't know how much a stock set of vortec heads can handle was my only concern
Old 12-24-2011, 02:04 AM   #5
cableguy0
That cam would be safe on stock vortecs. General rule is to stay below .480 lift as a max. I have seen some heads only be able to handle as low as .450 lift. Its kind of up in the air but in general no more than .480 lift is a safe limit. That cam wont sound really radical but will make good power on the low and mid range.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-24-2011, 03:40 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Just a thought , if staying mild on the cam why not run a factory Z28 cam . 94-96 F-body LT1 . They are like 204/208 450/460 This might save some money for you unless you need a fuel pump lobe on the cam .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-25-2011, 12:56 AM   #7
kennyhammond
I am going to go with a zz9 cam.... think it will be best.. and I am running electric pump
