Old 12-24-2011, 12:33 AM   #1
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Auto Shifting Issue
My truck is a 71 with 402 and TH400 auto with column shift. Currently it will shift freely between N and D L2 L1. With some effort it will go into reverse and absolutely refuses to go into Park. I think it's something in the column as I can't see anything external to the column that is interfering.
Is there a way to get to the part of the column that moves with the shifter by removing the steering wheel? Can you think of anything else to check?
Zoomin is offline   Reply With Quote
Old 12-24-2011, 12:35 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Auto Shifting Issue
check the parking pawl
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 12-24-2011, 01:10 AM   #3
PAWS 72
PAWS 72's Avatar
check adjustment on shift linkage also.
PAWS 72 is offline   Reply With Quote
Old 12-24-2011, 01:16 AM   #4
into69z
"brand new second-hand"
into69z's Avatar
I had the same problem-I found that the nut coming out of the trans was loose and causing the linkage to bind, so I cleaned everything,lubed it up and tightened it all down and worked good. It's time to do it again because it's starting to get hard to shift into park again. Lube and check everything on the column as well, you shouldn't need to open up the column.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
