87 TBI ... Temp and Oil Sender mess
I have an 87 R10 350 TBI. It's my daily driver and I just had the motor rebuilt. Upon reassembly I messed up some wiring somewhere, My oil gauge stays pegged passed 60 at all times, and my temp gauge seems to run with my oil pressure but backwards from 260... very strange because I've checked all my grounds 3 or 4 times now, only questionable ground I can think of is the one behind the distributor does it go to head, firewall, or bell-housing bolt?
Re: 87 TBI ... Temp and Oil Sender mess
More info.. Original Motor was a 305, someone along the lines swapped in a 350 , I also have both oil sender switch sensors gauge and idiot light, should I unplug one?
Ran various ground jumpers everywhere, if I ground the oil sender wire that comes from by the oil filter it pegs the temp gauge... I've got wires everywhere out of looms looking for shorts.
Posted via Mobile Device |
#4 | |
Get all grounds squared away - make sure EFI harness ground is connected at thermostat and ground straps as clean and tight. The oil pressure gauge runs of a combination switch - pressure sensing unit that picks up oil pressure from rear oil gulley, next to distributor. This unit is relatively large - easy to spot. This unit should have three wire weather-pack plug, which has orange, gray and brown color wires. Orange and gray are used for fuel pump backup (redundancy) switch and use larger gauge wires than brown. Brown wire is used for oil pressure light or gauge. If brown wire is somehow connected to it may peg the oil pressure gauge. Disconnect this plug from sending unit - see if gauge indication changes (while engine is running). It is also possible that your rebuilt 305 is equipped with high pressure oil pump (Melling M55HP or Sealed Power) and during idle it never drops below 40 PSI (cold oil and / or higher viscosity grade). The temperature gauge uses its own sending unit - green wire usually screwed into cylinder head. A wrong sending unit will cause funky readings, but a short to ground will cause temp gauge to peg (low resistance = high temperature.) Disconnecting temp gauge wire should result in low temperature reading at all times. If high temp indication remains check for harness short to ground. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Sounds to me like you have the wires swapped. You ground the wire at the oil sending unit and the temp gauge pegs?? Makes sense to me.
Ok I'm heading in the right direction, my name on here is bogus lol. What wire goes to the canister style oil sending unit by the oil filter, thanks for reply it's left me scratching my head, I do have the green wire in the wrong spot and the plug is connected on the oil switch by distributor..motor is now a350, swapped by PO. Btw Merry Christmas
Posted via Mobile Device Last edited by TrueChevyTech; 12-25-2011 at 04:10 PM. |
The oil pressure sending unit by the oil filter should have a moulded round end on it. The temp sending unit should have a hard plastic plug that either slides on or pushes on.
I can try and take some pics of the senders on my 87 if you need it. Merry Christmas to you too. |
yes it has the plug with 3 wires by the dizzy, but I can't find the wire for the one by oil filter
![]() Join Date: Apr 2009
Here is a wiring diagram from the ECM to all connectors with wiring color codes
![]() Here is another good link with some info.. http://fuelinjectionconnection.com/gpage5.html Desert Last edited by Desert1957; 12-26-2011 at 12:18 PM. |
I need to know what wire runs to this part that is located by the oil filter low on the drivers side. that is the wire that is grounded and causing my oil gauge to stay pegged, also .. i don't see where on that wiring diagram this wire i speak of is, and not sure i understand the designation of wires into the fuse block
#11 | |
yeah i see that was just for the ECM, i know the truck has oil pressure cause it runs, i'm just struggling with the gauge, the part i pictured i just replaced i must have pulled that wire out of the harness somewhere, do you know what color or where it goes into the fuse block at so i can trace it and find where it's grounded
#13 | |
Look at the back of the engine and trans and see if you pinched the wires in there. |
#14 |
Found the wires, thanks for the help. All that is left is timing sweet
#15 |
just for reference , here is the oil pressure sender in the diagram.
#16 |
I saw that one, but it's not for the gauge it's for the fuelpump. If i'm wrong please correct me.
#17 | |
Slots go on anything!
You are right on.
1974 Jimmy- 5.3/4L80e/NP241 |
#18 | |
#19 | |
Moderator
![]() Join Date: Oct 2008
1987 R/V Wiring Section 4 Page 1 DARK GREEN wire is the TEMP sender wire. Last edited by hatzie; 12-28-2011 at 02:38 AM. Reason: add schematic page |
#20 |
My bad sorry, Hey nice PDF on the wiring diagram.
Desert |
#21 |
Try Again - no PDF
#22 |
I was referring to post #19
