Old 12-24-2011, 12:00 PM   #1
mshewkin
Smile 1969 Chevy 396 CST 2wd to 4wd Conversion
I have a 1969 Chevy 396 CST Truck with Factory Rear Leaf Springs and would like to convert to a 4wd Truck.
I have a Donor 4wd Frame that was stretched with spring mounts and both axles that I believe is a blazer frame? How can I verify what it actually is?
Has anyone used the (FGB52) Kit by DIY4X? It is designed for 52" Springs. Is this the correct spring length to use in this conversion? Here is the link:
http://diy4x.com/cart/index.php?rout...product_id=122
There are alot of threads on successful conversions and since the Truck already has the Rear Leafs from the Factory, is this C10 Frame a good fit for a conversion to a K10 Frame Set-Up?
Any help or links to other treads/post would be helpfull. There is a alot of information here and looking for good advice before I jump in with both feet.
mshewkin is offline   Reply With Quote
Old 12-25-2011, 11:54 PM   #2
mshewkin
Re: 1969 Chevy 396 CST 2wd to 4wd Conversion
Does anyone know if the Blazer Axles are the same as the K10 Trucks?
Old 12-26-2011, 12:12 AM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Why?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-26-2011, 09:52 AM   #4
mshewkin
I was wanting to use the blazer front axle if was interchangeable for the 2wd conversion on the 69 CST Truck......
I don't know alot about the conversion process and I havn't had any luck in finding a good 4wd Frame to use other than the one I have which I think was originally a Blazer Frame lengthened to the Truck Length? I bought it mainly for the rust free cab someone had put on the rolling chasis......
I need alot of help on this project and setting up the front suspension will be the hardest part I'm thinking???
Old 12-26-2011, 11:25 AM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Post this in the 4wd section. There have been a few that can help you in this process there. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-26-2011, 12:56 PM   #6
47thriftmaster
47thriftmaster's Avatar
Yes, both the trucks and blazers used Dana 44, the 8 lug HD trucks used a HD Dana 44. 69-70 had drums on the front and 71-72 used discs.
47thriftmaster is offline   Reply With Quote
