Old 04-23-2003, 10:38 AM   #1
Brently
original am/fm radio
i am installing an original am/fm/ radio into my truck - for some reason the fins on the left side of the radio hits the wiper motor underneath the dash - i know that both are original because i took them both out of a truck - can you help please - Brent
Brently is offline   Reply With Quote
Old 04-23-2003, 11:51 AM   #2
Hutch
Hutch's Avatar
Is this the radio?
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-23-2003, 12:58 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Here is a delco radio model # decoder page
I've never seen such a problem. Does this radio have an optional stereo multiplexer on it? Do you have pics?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-23-2003, 01:13 PM   #4
Brently
truck radio
it is the exact same radio as in the picture - i don't know what a multiplexer is but is does have a grill like side on it that is hitting - help please - Brent
Old 04-23-2003, 01:36 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
A multilexer makes it a stereo radio which truck radios were not. Most of them are either separate units or bolted to the radio itself. See pic. Does your model number decode to a truck radio? Do you have a pic of the unit and dimensions? With that info somebody may be able to compare directly as I haven't had one in my possession for a couple of years.
Old 04-24-2003, 07:01 AM   #6
Brently
truck radio
is this multiplexer something that can just be removed? the numbers match a truck radio for this year model - i don't see a bolt where it can be removed but in between the fins there are two nipples with fastners holding them on - if i remove the fastners will the fins come off? i have seen these fins on the back but on this radio they are on the left side? help again please, Brent
Old 04-24-2003, 09:10 AM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
I wouldn't try to do anything based upon my limited advice. If possible take pics showing your dilemma or mesure your radio for dimensions. You already know this but it should go right in based on the info you've provided. I'm bumping this to the top in hopes somebody with a unit for direct comparison can help.
Old 04-24-2003, 10:04 AM   #8
Hutch
Hutch's Avatar
It would seem that the fins would be for heat dissipation.
If you only require a small amount of clearance then you might consider shaving them some.
Does the radio sit flush with the dash?
Is there a new gasket on the wiper motor?
Maybe install the radio then the wiper motor?
What model cab did it come out of and what model is it going into?
Just a thought
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 04-24-2003, 10:14 AM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes, I didn't state this but I don't think those fins are related to a multiplexer as these are normally bolted to the top of the unit not the side. Hutches questions are valid and a picture may clarify too.
Old 04-24-2003, 10:50 AM   #10
Brently
truck radio
i will try and get pics asap - don't really know how to put them on my post so may need some help - it came out of a 72 and going in a 71 - i thought about putting the wiper motor in after the radio but did not know if it would be any better - the radio fits in the hole perfect but you cannot raise it under the dash to be level because it hits this motor - any help would be appreciated and thanks - Brent
