Old 12-24-2011, 02:00 PM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
HEI Question
I am trying to hook up a tach on my HEI distributor. I'm from the old school where it meant hooking to a coil. I see on the HEI where it should be hooked but I don't know how it hooks. I looks like it takes a special plug that I don't have and don't even know what to ask for at the parts house.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 12-24-2011, 02:04 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: HEI Question
The "correct" plug has a little clip to hold it in. A normal female spade connector works great.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-24-2011, 02:08 PM   #3
kcsa75
kcsa75's Avatar
Re: HEI Question
I guess it depends on the HEI, but I just used a spade connector and all was good.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 12-24-2011, 02:19 PM   #4
BIG CHEVY 3600
Re: HEI Question
Your pic is female spade, is that the right spade?
Abraham Lincoln
Old 12-24-2011, 02:19 PM   #5
booger1949
Re: HEI Question
i used the same spade on mine
booger1949 is offline   Reply With Quote
Old 12-24-2011, 02:29 PM   #6
kcsa75
kcsa75's Avatar
Re: HEI Question
Yes.
Willie
'72 C10 Highlander
Old 12-24-2011, 02:33 PM   #7
BIG CHEVY 3600
Re: HEI Question
Thanks guys, the check is in the mail.
Abraham Lincoln
Old 12-24-2011, 02:53 PM   #8
Tims37chevy
Re: HEI Question
Or the next time your in the salvage yard keep your eyes open for an oe type connector
Tims37chevy is offline   Reply With Quote
Old 12-24-2011, 07:52 PM   #9
azsnow
azsnow's Avatar
Re: HEI Question
You can get them from Summit for under $5. All it is is infact a spade, but if you want the one with the clips, here it is. I am using the one for the power wire.
http://www.summitracing.com/parts/PCO-5664PT/
azsnow is offline   Reply With Quote
Old 12-25-2011, 03:08 AM   #10
mr48chev
mr48chev's Avatar
Re: HEI Question
The female spade does work but I had problems with the one on mine getting just loose enough to cause the engine to either quit or misfire. I finally picked up the correct one with the locking tang on it.
This is what you need and you should be able to get a similar one at the local parts house. http://www.repairconnector.com/produ...d-Repair-.html Nabbing a used one and a length of the heavy gage wire to go with it works too though.
Old 12-25-2011, 05:05 PM   #11
OrrieG
OrrieG's Avatar
Re: HEI Question
I just used standard spade connectors for my power and tach too. Does the factory clip type have both wires, or two separate like the Pico ones?
OrrieG is offline   Reply With Quote
Old 12-25-2011, 11:45 PM   #12
booger1949
Re: HEI Question
should have both wires
