Member #1049
Blazer top texture
Does anyone know what that stuff is?
The wife wants a smooth top on her Blazer and even though I have built dozens of Blazers over the years I have never attempted a smooth top before. Has anyone smoothed their top? how did you do it? Sand it down? use fiberglass stripper? I could use any hints at all!! |
Re: Blazer top texture
It's the way the fiberglass is molded. If you want a smooth top the best way is to block it all down, either with an air board or good ole' fassion man power
I've done with my blazer top and it was easy..just sand it smooth...
(sorry i'm in the wrong year section but i like all blazer's ![]()
1990 k5 blazer 1990 gmc jimmy 1949 1300 p/u-sold 1977 bbc skylark 96 roadmaster 06 9c1 impala |
#5 | |
SKINNY TIRES RULE!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
![]() Join Date: Jun 2004
I've been asking about how to get the texture finish and nobody seems to know. I was gonna use bed liner but everybody advises against it. I wanted white. I contacted the bedliner mfg (Herculiner) and they agreed - - "it will not stay white - it will grey or yellow". So - - I have been sanding - filling - sanding - filling - sanding. I'm about ready to shoot it - smooth.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
I used Al's Liner, tinted white, it is garage kept but still looks good. You have to use a high grade tint $$100 a quart
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
I'm going with Durabak bed liner. Supposed to be real tough, easy to apply, comes in a bunch of different colors, and works on fiberglass. Also comes in either a smooth or rough texture. I've never used it though, I couldn't tell you how good it is.
http://www.durabakcompany.com/
1972 k/5 Blazer 350V8/TH350/NP205 "The Ox"
I smoothed mine with a flat sanding airboard and fill in primer and it is very slick just remember even with a board fiberglass will always be wavy
I repaired mine and attempted to mimic the texture with no success. Went to a local body shop and they did a wonderful job with the finish. $100.00 well spent!
Member #1049
That is the process that I am leaning towards doing. I do know it will still be wavy and have explained that to the wife and she still wants smooth..
Doesn't have to be wavy, just takes alot of block sanding and filler, your arms will be tired
Fill in primer won't do it alone, that's more of a finish work procedure, then block that with a guide coat to see where you are at.
#13 |
Using one of these will help getting out the waveshttp://www.autobodytoolmart.com/dura-block-2-58-x-30-marine-sanding-block-af4410-p-16007.aspx
#14 |
I sanded mine with 80 grit on a d/a sander; stripped the factory coating right off, primed then painted. I'm not concerned about it being wavy, and it doesn't really show much if you go white.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#15 | |
Member #1049
When I mentioned about it still being wavy it is the factory dip/sag in the middle of the top I was refering too.. the sides and most of the rest will be glass smooth, The wife is leaning towards painting it Parchement like the interior. |
#16 |
I think the factory sags are something we as Blazer owners might have to live with, haven't seen any cures for them. Out of site out of mind
#17 |
From what I gather, I believe that issue is a double wall top problem. The single walls don't have the sag or wave issue.
#18 |
My single does sag just not as bad as the double wall I trashed
#19 |
Interesting. Mine is flat as a pancake. I would think here in the AZ sun would be the worst for it?
I've heard others here say the double walls were the worst, and singles weren't a problem. Something about the design change with more support. |
#20 |
Member #1049
I have 3 double walls and they all sag, The one on the wifes Blazer is a single wall and it has a sag but no where near as bad as my double walls
#21 |
I also have a question concerning these tops. According to my SPID, my top was originally black, a PO painted it white at some poit. I want to go back orginal. Did the black tops have a flat or gloss finish from the factory? Was the underside black as well? I see many photos of black tops with white undersides.
#22 |
mine is factory black....it is faded pretty badly so i don't know if it was satin or gloss or what. the inside is white though. i know the PO didn't repaint it.
#23 |
Member #1049
The wifes single wall is also black with a white inside, it too is so faded I am not sure if it was originally gloss or flat.
| Bookmarks |
