OutOfMyMind & I'llNeverKnowWhy
Ram air setup
I just got done setting it up. Still needs paint and screens over the intakes so litter and birds don't get sucked in.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! Last edited by Justins76; 12-24-2011 at 08:30 PM. |
Re: Ram air seup
some more pics
Re: Ram air setup
how you plan on gettin air in the engine with the thermacs shut? i dont think youll have a problem with water getting in while driving in the rain even with them open.
Re: Ram air setup
Looks nice. I had planned on doing this until I decided to go blow thru.
84 GMCummins 91 CCSB Dually american squarebody association |
Re: Ram air setup
Looks nice and factory even You may want to put a flat surface covering the direct intake of bugs and so on. I wouldn't worry about the moisture being mounted that high. I have seen an older police cruiser with the air intake mounted below the bumper. That worked well until the officer tried to go through a small stream. It sucked up the small stream into the engine and bent every rod in the engine. But being mounted that high you wont have a problem, in fact moist air makes more power and economy.
I did a little trickory to my dad's car years ago by putting a sponge just outside the air filter element and kept it moist with a small water pump. It did increase his fuel mileage on a long trip (72 Duster 318 cu in. 24.5 mpg @75 -80 mph. California to Texas with the AC on). |
Re: Ram air setup
I found this set up a while ago but dont have the money for it. Looks sweet tho.
http://www.spectreperformance.com/#CATALOG.905111
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Re: Ram air setup
Take the thermacs out completely to get better air flow I did a one side ram air with the stock system. Getting rid of all the baffles and flaps plus cutting the plastic piece on the core support. Did quite good thing for the 305
Also the smoother the tubing you use the better the air flow. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
