Old 12-24-2011, 11:36 PM   #1
demon79
demon79's Avatar
transmission question
is there a way to put a th-400 in my 1999 1-ton i ask because trans is shot in my 99' and i have a good th-400 from a project that stalled any help is appreciated thanks
1965 chevy short bed step side "angel" 366 bbc/th-350 auto
1999 gmc sierra "terra" 350/4l80e
1983 pontiac firebird "kat" 350 lt-1 paxton supercharger/t-5 5-speed
demon79 is offline   Reply With Quote
Old 12-25-2011, 08:24 PM   #2
clinebarger
Re: transmission question
Yes it can be done, The drive shaft will need to be lengthened, The cooler lines reworked, A flexplate for a 4L60E, or a 3L80HD converter. The 4L80E shift shaft is longer than a TH400....might run into some problems with the shift cable. The neutral safety switch wont work (dangerous). The PCM will need the trans functions flashed out or stare at a permanent check engine light. Fab up a electric kick down switch.
Do yourself a favor & rebuild or replace the 4L80E.
clinebarger is offline   Reply With Quote
Old 12-26-2011, 07:58 PM   #3
karlbenz
That answered a question of mine also
karlbenz is offline   Reply With Quote
