12-24-2011, 11:58 PM | #1 |
lincoln plasma trouble
Anyone have trouble with a lincoln pro cut 20 plasma not working?when I try to use mine air will flow thru the torch head but it will not start an arc.Tried new consumables and that did not help.Thanks
12-25-2011, 01:44 AM | #2 |
Hollister Road Co.
Re: lincoln plasma trouble
You will have to perform the Torch Continuity and Solenoid Test. Look in your manual or go to lincoln eletric and find your manual. It sounds like the trigger or solenoid may be bad. Is is running at 60 psi? When you pull the trigger do you hear a click in the machine?
12-25-2011, 02:34 PM | #3 |
it has been a while since I have tried to use it,but I will try to check some things and post results.
12-25-2011, 02:53 PM | #4 |
from what i have been told u must maintain a realy good ground or u will have problems with your machine
nice clean air will make consumables last longer too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-25-2011, 04:28 PM | #5 |
Hollister Road Co.
Good ground on these is important but it should get a pilot arc even without a ground. Oily consumables can also cause issues.
04-08-2012, 08:36 PM | #6 |
update on the plasma,I now have a refrigerated dryer with a water trap and a motorguard 60 filter.I used my plasma tonight,it cut about 3 inches,i stopped to reset my guide and the safety light was on.I put new consumables in it and it will not strike an arc.I am really at a loss as to what is wrong.
