Old 12-25-2011, 05:28 PM   #1
swyfor5
swyfor5's Avatar
Mi. Shock upgrade for o4 Sierra ext. cab 4x4
Looking at replacing the stock shocks on my 04 GMC Sierra ext. cab 4x4 Pickup. Only 20,000 miles on the originals, but they just look wimpy. Anybody got any advice here?
swyfor5 is offline   Reply With Quote
Old 12-25-2011, 08:25 PM   #2
clinebarger
Re: Mi. Shock upgrade for o4 Sierra ext. cab 4x4
One word.....Bilsteins
clinebarger is offline   Reply With Quote
Old 12-26-2011, 01:34 AM   #3
edhtrd71
Bilstein 5100s are great. Huge difference on my 05.
edhtrd71 is offline   Reply With Quote
Old 12-26-2011, 04:50 PM   #4
swyfor5
swyfor5's Avatar
Any advice on what Bilstiens to get for stock setup? Looked, but most are for a lifted setup.
Old 12-26-2011, 08:42 PM   #5
clinebarger
http://www.eshocks.com/bil_veh.asp?M...tein&SubChar=Q
Old 12-26-2011, 10:23 PM   #6
edhtrd71
If your truck is stock use the 0-2 inch models. The shocks on your truck are the droop bump stops. There is a little more travel available and the bilsteins are designed a tiny bit longer to allow more travel. If your torsion bars are cranked up and you get alot of rough rebound going over speed bumps these will smooth it out alot.
Old 12-27-2011, 01:40 PM   #7
swyfor5
swyfor5's Avatar
Thank's guy's! Clinebarger that link is what I was looking for! Thank's again!
Old 12-29-2011, 06:08 PM   #8
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Another vote for bilsteins. After running a few different shocks and then Bilsteins, I will never run anything but.
BTW if yours is a Z71 the stock shock should be Bilsteins, although the aftermarket 5100s will have slightly different valving, and available in a zinc coated finish rather than the blue/yellow.
Also as edhtrd71 mentioned the stock shocks are about 1/2" too short in the factory application, although not actually the "droop stops". Someone at GM dropped the ball on those as the shock does top out before the suspension droops to the actual droop stops. Bilstein's 0-2" shocks are just a tad longer and allow those stops to do their job correctly.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
