Old 12-25-2011, 05:59 PM   #1
texastrendz
gen lll swap fuel cell?
I purchased an aluminum fuel cell for my 67-72 truck that I am installing an ls based motor. I want to run an external fuel pump and filter. My fuel cell does not have a return bung welded into it. Can i run the return through the roll over vent or do I need to weld a return bung into my tank. I have a truck style motor with a return line coming off of the rail. thanks daniel
texastrendz is offline   Reply With Quote
Old 12-25-2011, 06:27 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: gen lll swap fuel cell?
Take the tank to a local shop to weld one in. Don't use the vent.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-26-2011, 02:08 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The vent on my cell was a -8 AN bung, so I used the vent for the return and switched to a vented cap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-26-2011, 02:34 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
When I modify cells for people who need return ports, I usually use a -8 or -10 AN bulkhead fitting, cutting a hole at the opposite end of the pick up/sump like these - http://www.summitracing.com/search/D...head-Fittings/. If you go this route and if there has been fuel in the cell, use an air drill. Obviously, clean out all of the debris. I ended up modifying the fill plate on my cell for an extra return off of the high pressue regulator at the pump (I run an external EFI pump).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-26-2011, 05:58 PM   #5
texastrendz
These are two fittings on the tank I have. Top is the feed and the brass is the rollover vent. I am thinking of changing all the fittings to AN -6. I can buy all the bungs and have them tig welded on top of the NPT threads. I am thinking of turning the feed line into the return line and tig welding a -6 AN fitting to the bottom right corner for the feed line. Do yall see a problem with this?
Old 12-27-2011, 02:53 PM   #6
vin63
vin63's Avatar
I would use at least a -10 AN for the supply to the pump, and -8AN for the returns (fuel volume over time consideration)...this will also help keep the fuel cooler.
Old 12-27-2011, 08:14 PM   #7
texastrendz
That seems big to me, this is my first ls motor. I was going to run 3/8 aluminum line for the feed and return and all -6 fittings since it is the same size. Is this to small for a stock ls 5.3 motor?
Old 12-27-2011, 08:19 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my fuel feed is also 1/2" aluminum hard line and -8 stainless flex hose.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-27-2011, 11:22 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm running 3/8 both ways without issue.
