Old 12-25-2011, 10:06 PM   #1
awitate
gas tank conversion problems
Everybody says this an easy project. So far i've had to remove the rivets on the spare tire cross bar, notch the cross sill bar, drill 2 holes on the frame and i've also notched a piece out of the frame to allow for space for the filler neck on the tank. It seems like 1 of the tank straps is inside out. my Question is do i need the straps? Can I bolt the tank to the frame and call it a day. I can't figure out why i need the straps. I'm using the metal 69-72 blazer/suburban tank from american classic. This tank looks exactly like the tanks from everybody else. This is going on a 63 short bed fleetside btw. I have looked at tons of posts but there are too many variations to find the answer i'm looking for.
awitate is offline   Reply With Quote
Old 12-26-2011, 01:25 PM   #2
rbar
rbar's Avatar
Re: gas tank conversion problems
Could be some very valid points. Another thought process could be it was easier for the factory to not make a tank with flanges strong enough to bolt to the frame and two straps with only one nut on each strap was cheaper and quicker. As for ease of installation, I installed the cpp aluminum tank and it bolted right in to the frame just fine, although the sending unit instructions were completely wrong.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 12-26-2011, 09:32 PM   #3
lil_sahara450r
glad to know im not the only one that had major issues with the cpp instructions. when you pay that kind of money for a tank, you expect it all to bolt right in... im done with cpp after this. and they didnt wanna help me out when i called them out on it. the tank was great but everything else was a MAJOR thumbs DOWN!!!
lil_sahara450r is offline   Reply With Quote
Old 12-26-2011, 10:40 PM   #4
Money Pit C-10's
No CPP tank. Got it..
Money Pit C-10's is offline   Reply With Quote
Old 12-27-2011, 01:08 AM   #5
awitate
Yeah, from everything i read the 69-72 blazer/suburban tank was suppose to be virtually plug and play. I've had to fabricate and modify alot of stuff already and i'm still not finished. For anybody that is considering this mod i think the more expensive but simpler looking tanks could be the way to go. By the way, I'm guessing that no matter where you get the blazer tank from its going to be made in china.
Old 12-27-2011, 01:26 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I agree with the concept that straps are needed on a tin tank originally designed to be attached in that manner. Bolting the flanges to the frame will likely rupture the tank after enough twisting frame cycles.
I have a custom Rock Valley tank that holds 33 gallons. Mine bolts to the frame rails via welded angle flanges on the side ends of the tank. I had some concerns about long term strength because of the weight, and the fabricators resolved the problem by making the end panels and brackets twice as thick as the tank, which is already 2-3 times thicker than the stock tank. I'd worry about using this mounting method unless if was a tank designed for the purpose like the Falcon tank.
Old 12-27-2011, 02:06 AM   #7
awitate
I guess i'll take everyone's advice and use the straps . Wouldn't have been so difficult if they were both the same. Thanks everyone for the advice!
Old 12-27-2011, 02:06 AM   #8
rbar
rbar's Avatar
I really like the CPP aluminum tank with the flanges bolting the the frame. It fit right in. They just give you a universal sending unit and then give you instructions that say not to rotate it and to cut it to a certain length. Then it won't work without rotating it and the sending unit will be cut to the wrong length. Each purchase I have made through them results in a problem that they steer me the wrong way, or have no idea of what to tell me, as in the case of my emergency brake cables that they could never tell me how to hook up. That's once they manage to get the parts that are really really late. But, like I said, I like the tank.
1965 Chevy swb 383
Old 12-27-2011, 03:27 AM   #9
pdxhall
pdxhall's Avatar
There are many tanks in autos that are bolted directly to the frame or subframe including the Falcon tank mentioned above and the Mustang tanks, and many others. I have an early mustang tank that I bolted directly to the underside of the top frame rail and is sandwiched between the frame rail and a 1" wide steel strip. I don't see a problem with bolting to the frame rails unless you are doing some major frame twisting launches in racing or in rock crawling. The frame and the crossmembers are very stout. You might have a problem if you don't have any suspension underneath but that's unlikely.
pdxhall is offline   Reply With Quote
Old 12-27-2011, 06:13 PM   #10
neto
neto's Avatar
I put the CPP tank in also and had the side mount filler. I had to cut the frame also and bolting the tank wasn't that bad just drilling the holes were fun. In retrospect I would have looked for a tank that the filler hose goes above the frame. I think early classic has one out of stainless steel. Just the price of 700 plus was a little high for me this time.
neto is offline   Reply With Quote
Old 12-28-2011, 04:48 PM   #11
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: gas tank conversion problems
You can take a look on how I done mine on my Ole' truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
https://skydrive.live.com/?sc=photos...1365&sc=photos
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-28-2011, 11:45 PM   #12
rbar
rbar's Avatar
I have posted this once before, but drilling was easy this way.
1965 Chevy swb 383
Old 01-12-2012, 10:12 PM   #13
Clownpuncher
Clownpuncher's Avatar
To the original poster. The tank in my truck is from a 69-72 K5 blazer and it fits perfectly.Some of the flanges had to be bent up towards the front but that's because of the "C" notch
Chuck D
66 C10 LS6/4L65e
Clownpuncher is offline   Reply With Quote
Old 01-13-2012, 12:10 AM   #14
awitate
Mine is a reproduction from china so I'm guessing its close but not exactly the same as an original 69-72 blazer tank. It does fit but I still had to do alot of stuff to it and the truck to make it work.
Old 01-13-2012, 12:24 AM   #15
monolith
Zero Albedo
monolith's Avatar
Just today I installed a 50 gallon tank in my panel- bolted to the frame-for detalis check the panel thread in my sig
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 01-13-2012, 12:31 AM   #16
mud.man.rj
mud.man.rj's Avatar
I don't know if any of them are to easy, i put a poly sub tank in the rear of my 71, no fun at all, a lot of mods. But it's done now and way better than in the cab. Got some in cab room now, not quite an extended cab but enough for a sub box.
mud.man.rj is offline   Reply With Quote
Old 01-13-2012, 06:52 AM   #17
purebred
I bought the 21 gallon tank from LMC and didn't have any problems except the crossmember for the filler tube, but I guess that is why these trucks are fun, challenging but real satisfaction when done.
purebred is offline   Reply With Quote
Old 01-13-2012, 09:30 AM   #18
LDO
LDO's Avatar
I purchased the 19 gal from POL. As with the CPP kit, the tank looks good and installs well but i had the exact same issues with the sending unit as others have. Only worked if you 'clocked' it and if you follow their instructions, it ended up being cut incorrectly. I was reading empty with about 7-8 gallons still in the tank.
Their customer service however, was fantastic and they sent me another sending unit no questions asked.
LDO is online now   Reply With Quote
Old 01-13-2012, 10:02 AM   #19
Iron-Butt
454 club
Iron-Butt's Avatar
Will the cpp tank hang to low if the truck has air bags? was you able to get the sending unit to read with the factory guages or are you using an after market guage.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 01-13-2012, 01:19 PM   #20
DLOE65
DLOE65's Avatar
Anyone use the universal fuel cells from summit or jegs?
DLOE65 is offline   Reply With Quote
Old 01-13-2012, 04:46 PM   #21
rbar
rbar's Avatar
My truck still isnt together, so I don't know on that one.
1965 Chevy swb 383
Old 01-13-2012, 05:07 PM   #22
jimmydean
jimmydean's Avatar
The RCI 17 gallon is 30" L x 17" W x 7" H and if you trim the inside of the top of the frame rail, it sits nice. My bed will me raised, so the extra few inches aren't an issue.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-13-2012, 07:35 PM   #23
ctumbler
ctumbler's Avatar
So bought my 66 with what I believe is the cpp kit already installed, the PO had no idea who had done what to the truck, bought it with no mechanical knowledge at all, so I am trying to decode what the previous previous owner did. The PO did tell me something similar, that it would read E even with a half a tank left, and that with a half a tank reading there was a full tank - or something to that effect.
I am in the process of going through all the issues with the truck, how did you "clock" the sending unit? Seems like easy access with no bed floor - just not sure what resistance I should be getting off the sending unit back to the dash for "E" "1/2" and "F"
ctumbler is offline   Reply With Quote
Old 01-14-2012, 02:56 AM   #24
Clownpuncher
Not the best picture but here is my truck with a 69-72 K5 Blazer tank
It would only work if you had a raised bed floor, Unless you strapped it but I think then it would sit to low. To me this looks like the same tank Brother's uses as their kit to move the 60-72 gas tanks under the bed.
Chuck D
66 C10 LS6/4L65e
Old 01-14-2012, 04:06 AM   #25
rbar
rbar's Avatar
The sending unit came so that it would swing to the left and hit the tank wall. With it turned to the correct way like my photo, the bolt holes did not line up. I had to loosen the top nut and rotate the top plate so that it would swing to the right instead. The other part that caused me to be worried was that the sender instructions said not to do that. I had to send CPP photos and they told me to do it, it wouldn't hurt it, so I did.
1965 Chevy swb 383
