Old 12-26-2011, 12:58 AM   #1
C4 Metal Werks
C4 Metal Werks's Avatar
Emergency Brake Lever-Won't Ratchet My
My E-Brake lever wont stay engaged. Not sure what the issue is but the release handle is no longer spring loaded. Is this an easy fix?
C4 Metal Werks is offline   Reply With Quote
Old 12-26-2011, 01:18 AM   #2
cb1965
cb1965's Avatar
Re: Emergancy Brake Lever-Won't RatchetMy
i took mine off and cleaned it real good and lubricated it. works great now
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 12-26-2011, 01:21 AM   #3
C4 Metal Werks
I can try that. What ever was spring loaded is no longer.
Low & Slow
Old 12-26-2011, 12:29 PM   #4
'63GENIII
'63GENIII's Avatar
X2 Could also be that the spring for the pawl has broken, but I'd start with a good cleaning and light oiling. Mine would do the same thing until I put a little oil on it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-31-2012, 04:06 PM   #5
gofastnut
gofastnut's Avatar
Re: Emergency Brake Lever-Won't Ratchet My
Same here. I had to block the tires in the driveway to keep it from rolling til I got the thing cleaned/oiled.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
