12-26-2011, 01:17 AM | #1 |
motor oil post
I know I have stumbled across a thread here that had what motor oils guys were using. I cannot find it. I have a 283 that I want to service this week. Normally my family is a Quaker State family and will go that route if push comes to shove. For some reason I thought guys were going the synthetic route. It is the original motor in my 66, runs well, little over 100k.
12-26-2011, 10:12 AM | #2 |
Re: motor oil post
You may want to search the internet ,specifically the oil companies websites and see what their recommendation is .. GM recommended a "low ash parafin base oil" that was the days of straight weight oils and most old engines ran just fine on them .. technology now concerning oils is way advanced from what it was back then ... From my own experience , I look at what the oil pressure is hot , and whether or not it uses oil... My 63 that I ran years ago used oil if I ran 10-40 , but it used half as much if I ran 15-40... my 97 7.4 has 60 psi all the time so I run 5w-40 syn. in that and it uses no oil.... zinc additives are available from a lot of suppliers.......
12-26-2011, 11:22 AM | #3 |
Re: motor oil post
Go ahead and use the quaker state,you have hyraulic lifters and I would use 10w40 especially if your motor is original
12-26-2011, 11:42 AM | #4 |
Re: motor oil post
perfect, thank you both.
12-26-2011, 11:50 AM | #5 | |
It's Better With Nitro
Re: motor oil post
For what it's worth, I'm a lubricants retailer in my home town, and I run synthetics in my newer daily drivers, but run Brad Penn (conventional) in my hot rods and race cars.
12-26-2011, 11:57 AM | #6 |
Resistance is Futile
Re: motor oil post
I use any different brand of oil. The problem now is the lack of zinc in adequate levels for flat tappet engines. My local parts store carries Edelbrock zinc which I add. 20 bucks a bottle; may be a cheaper brand but this is close to me so I get it on the way by the store.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-26-2011, 04:37 PM | #7 |
Re: motor oil post
What does flat tappet and stock 1966 283 have in common?
12-26-2011, 05:11 PM | #8 |
Re: motor oil post
12-26-2011, 07:58 PM | #9 |
Re: motor oil post
12-26-2011, 08:10 PM | #10 | |
Re: motor oil post
It is important to have higher ZDDP levels upon break-in of a new engine, including a flat tappet cam-lifter combintation. But, once the break-in is complete on a stock engine, it is not necessary to maintain the high levels of ZDDP. Combined with the fact that the OP noted that this is for the original engine with 100+K miles on it, any of the premium oils, including the Quaker State that he prefers, is fine. Since his engine seems to be running fine with what he was running before, there really isn't a need to start doing anything differently, such as switch to synthetics, or add costly additives. In his case, the viscosity will be more important than the ZDDP levels...keep in mind, an oil with tons of ZDDP, but too little viscosity will not protect the cam and lifters.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 12-26-2011 at 08:20 PM. |
12-26-2011, 09:10 PM | #11 |
Re: motor oil post
OH NO!!! A oil thread.
12-26-2011, 10:03 PM | #12 | |
Re: motor oil post
Comp Cams additive runs about $10 a pint,and I consider it cheap insurance considering what it costs nowadays to change your oil in the first place.
RIP Baby Jack 2-06-07 See You On The Other Side My Little Man |
12-26-2011, 10:09 PM | #13 |
Re: motor oil post
The only times I see distributor gear failures is 1 , late model chevys with roller cams and melonized gears , and 2 when people run more oil pump than they really need , ie a HV pump when the engine has clearances that require a std vol. pump ...
12-26-2011, 10:17 PM | #14 | |
Re: motor oil post
12-26-2011, 10:20 PM | #15 |
Re: motor oil post
I'm running redline synthetic in a stock 78 LG3 305 that has never been rebuilt and probably has a street value of $40 at best. But i'm not taking any chances.
Yes, the oil changes cost more than the engine itself! Am i saying this is the way to go? No, all i'm saying is i don't really know, but i'm not taking any chances. |
12-26-2011, 11:05 PM | #16 |
Re: motor oil post
I agree with Vin63...The lifters are spinning....They have been spinning for 100,000 miles on a mild cam with weak valve springs......Run whatever oil you want.
12-27-2011, 02:54 PM | #17 |
*** That's interesting ***
Re: motor oil post
Lots of finger pointing regarding this issue for years. Here is the conclusions I've drawn over the years. Yes, ZDDP levels have been lowered in modern oils due to their affects on catalytic converters. And yes, many hard parts like cams and distributor gears have seen quite a few problems recently. Is it due to the oil? Is it due to cheap Chinese metals? Is it due to the influx of "do it yourself" wrenchers and/or improper installation or break-in? Perhaps the real truth is somewhere in the middle of each of those issues.
On older cars with well worn engines, it is safe to say that cheap metal or improper break-in is not a factor. So the only concern at that point is the oil. Personally, I run Havoline 10W-40 from a 10 year old stash I found in my parent's garage in my flat tappet cars. And none of those are daily drivers, so that stash should last me quite a while. When that runs out, I'll just use a name brand oil, and throw in a bottle of ZDDP additive and call it a day. Just in case.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
12-27-2011, 10:30 PM | #18 |
Re: motor oil post
I have a little blue bottle of stp that claims to have zddp.Is any body using this stuff?
12-27-2011, 10:54 PM | #19 |
Grandpa in the rustmobile...
Re: motor oil post
Ive ran the vr1.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
