Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-26-2011, 12:10 PM   #1
HotRodGMC68
HotRodGMC68's Avatar
Drag Shocks?
Hey folks.. I'm in the market for a nice set of front drag shocks for my '68 GMC. What can you guys recommend?
384 Stroker Small Block-
Best ET: 13.24@103
HotRodGMC68 is offline   Reply With Quote
Old 12-26-2011, 12:24 PM   #2
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Drag Shocks?
Afco.
ProStreet68SB is offline   Reply With Quote
Old 12-26-2011, 02:50 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: Drag Shocks?
What is your budget? Are you looking at coilovers? Single or double adjustable?
I run a double adjustable QA1 coilover set on my Super Gas car.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-26-2011, 06:59 PM   #4
kpeztruck
kpeztruck's Avatar
Re: Drag Shocks?
If bolting in stock location, I recommend QA1 stocker star. Compression is permanently set stiff, and rebound has 12 settings. They worked well on the stock front suspension. Paul
kpeztruck is offline   Reply With Quote
Old 12-27-2011, 03:55 PM   #5
HotRodGMC68
Re: Drag Shocks?
I'm looking for something budget minded.. I was looking at the Competition Engineering 2615 adjustable shocks...? The suspension is stock style, stock shock location. Will be using Moroso Trick springs, drop spindles, nothing fancy.
Best ET: 13.24@103
Old 12-27-2011, 04:09 PM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Drag Shocks?
I really like Strange stuff. Have their single adjustable coil-overs on my camaro and love them.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-27-2011, 04:13 PM   #7
kpeztruck
kpeztruck's Avatar
Re: Drag Shocks?
The QA1 stocker star R series part # TR505 is 159.00 each through Summit. I believe I paid a little less through a local speed shop here in Atlanta. Paul
Old 12-27-2011, 04:23 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Drag Shocks?
I have competition engineering shocks on my Vette and they work great. Keep in mind that my car has more weight in the front than most pick ups do that are drag racing.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-28-2011, 01:32 AM   #9
chevytruck1970
chevytruck1970's Avatar
Re: Drag Shocks?
The tr505 is a t bar on bottom with a stud on top how did you have that mounted?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 12-28-2011, 12:14 PM   #10
kpeztruck
kpeztruck's Avatar
Re: Drag Shocks?
Oops, that is just the part # that the Summit site spit out when I searched for our trucks. The price should not be any different though. YOu might have to call QA1 to get correct part#'s, then order from a dealer. Sorry about that, the photo showed eyes on both ends, so I went with it. Paul
Old 12-28-2011, 01:03 PM   #11
chevytruck1970
Re: Drag Shocks?
Tr403 is the number I came up with the price is the same
Justin
1.35 60ft
Old 12-30-2011, 06:16 PM   #12
bcdeutsch731
bcdeutsch731's Avatar
Re: Drag Shocks?
I have the Chris Alston's Vari-Shock, it's Double adjustable and fits in the factory location. I like them a lot but they are expensive. I may be selling them soon if I get a new dropmember that uses coil-overs.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning.
8.3@168mph 1700+ HP
bcdeutsch731 is offline   Reply With Quote
Old 12-30-2011, 08:55 PM   #13
Blue Rat
Re: Drag Shocks?
What about rear shocks? Mines a 71. Don't mean to HJ thread.
Blue Rat is offline   Reply With Quote
Old 12-30-2011, 09:15 PM   #14
bigboybodry
bigboybodry's Avatar
Re: Drag Shocks?
I Installed the new front shock location brackets from cpp that mount to the top of the frame rail to add a little more travel because my truck has drop springs and spindles. Then I called summit and give them the ride heght of the truck and the sent me a set. They work great on the street but I have not been to the track with them installed yet.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
