Old 12-26-2011, 05:31 PM   #1
socalkevin68
socalkevin68's Avatar
Question need advice quick...
Hi guys...need your expert advice quickly as I have a chance to buy a suburban today for 500 bux....
Question is..I have a 68 c/10 with stock 292 6 cyl...and 4 speed...
this suburban has 350/350 in it....will it bolt right in?
Will all the parts from 73 suburban allow me to swap engine into mine?
it also has disc brake front end...will this fit on my 6 lug drum brake front end?
thx ...for any help
socalkevin68 is offline   Reply With Quote
Old 12-26-2011, 06:12 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: need advice quick...
If the engine and transmission are in good shape, buy it and then worry about getting the required parts.
Some things that come to mind along with rear crossmember, is automatic transmission linkage, radiator for automatic transmission, engine mount towers for V8, the automatic steering column. Could be more parts. I got all of mine from a donor truck.
68gmsee is offline   Reply With Quote
Old 12-26-2011, 06:38 PM   #3
john_p
different motor mounts.. pretty easy swap.. send me that 6... it is worth about as much as you're paying.. if you were on the east coast, i could help with the swap..
john_p is offline   Reply With Quote
Old 12-26-2011, 07:48 PM   #4
socalkevin68
i'd give you six if youd help me swap motors lol.....
