70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Spid Question
I found this truck for sale and the owner sent me pic of the spid. I see the code for "Manual Throttle" and my question is, by 1971 didn't all the trucks have an automatic choke on them? With that being said maybe a "Manual Throttle" was available because, depending on what you wanted to do with the truck, you may need it to stay revved up for sustained periods.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: May 2011
Re: Spid Question
Maybe was that like a throttle lock? Didnt they have some type of cruise control option?
![]() Join Date: Sep 2001
Re: Spid Question
I like to call it poor man's cruise control. As explained it is a dash controlled cable that will maintain a set throttle position. I would use it like cruise (the speed would just go up and down depending on hills, wind etc.). Cool Option!
Roadtrip!
![]() Join Date: Feb 2003
Re: Spid Question
The manual throttle had nothing to do with the choke. For some reason i have seen quite a few manual throttles on blazers. And yes, it just held the throttle at a certain rpm.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Spid Question
My 72 4x4 has the manual throttle. Farmers used them because it turned feeding the livestock into a one man job. Set the throttle, put trans in low gear and throw hay bales as truck eased down the feed line.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
its all about the +6 inches
Re: Spid Question
They were also common on trucks that carried campers. It would be used to chearge up the battery(s) and/or to keep the coolant heated up if the owner added a second heater run off the engine cooling system. This truck looks like it may have been optioned for camper duty.
Posted via Mobile Device |
#7 | |
![]() Join Date: Feb 2001
Re: Spid Question
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: Spid Question
The option is discussed in my `71 owner's manual.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
Re: Spid Question
I have a 71 owners manual downstairs, I'll look it up.
#10 | |
Re: Spid Question
1969 Custom 30 wrecker
Re: Spid Question
I would think most anything that has a PTO should have one.
My wrecker of all things did not come with one but had one added when it was converted to a wrecker by that company. (truck was a cab/chassis from factory)
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
