Old 12-26-2011, 06:46 PM   #1
waspp
waspp's Avatar
Steel wheel advice needed
Ok I am looking to use steel wheels on my 63. Originally I wanted to use the white dog dishes that came with the truck but with a wider wheel. I am planning on using a dropped spindle with 6 lug discs. I have seen on some other posts that the 15x8 rallies rub in the front if the truck is lowered but a lot of people seem to use them, is that the case? Also what back spacing do I need if I choose to order or buy a steel wheel? It seems a wider wheel would work on the rear maybe up to 10" and maybe a 7" would be good on the front. What have you guys found out and what do you recommend? Thanks in advance
Hal
waspp is offline   Reply With Quote
Old 12-27-2011, 12:57 AM   #2
SCOTI
SCOTI's Avatar
Re: Steel wheel advice needed
Hal
If you're wanting to run OE 15" steelies w/the poverty/dog-dish caps & are already swapping to front disc brakes, I would consider swapping to 5-lug wheels too. It's very easy to find the 5-lug front wheels as 15x6.5" plain steel wheels came on a bunch of trucks and/or full size GM cars w/the full hub caps.
The rears can be found aftermarket in 8" or 10" widths. I'm not 100% sure, but I would imagine they're available in either 5 or 6 lug.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-28-2011, 06:25 PM   #3
brokenspoke
brokenspoke's Avatar
I used 1972 Chevy camper wheels on the rear of mine....8 inches wide 5 lug
brokenspoke is offline   Reply With Quote
