Incoming cool air setup.
What kind of setup do you have for pulling cool air from outside the truck? I am trying to decide on what setup would be best for getting cool air to the carb. I have a 71 C10.
Re: Incoming cool air setup.
I guess everybody just runs the plain old round paper filter.
Right now I don't run a hood, have a K&N Filter as well as a K&N Top filter.
When I put the fiberglass front end on (with 4" cowl), I will make an air pan and pull cool air front the cowl.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
I am considering the same thing with the cowl hood. Just curious about what everybody is doing.
Yeah baby!
If this works, this is my set up. Hoses connect to the front grille.
11.37 @116 |
Registered Truck Offender
Cowl hood with a lexan air pan sealed to the underside with the regular old Moroso foam kit.
http://www.small-block-chevy.com/ima.../66airpan1.JPG wow, that's a stupid big picture,, sorry, changed to a link
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
I have similar ideas too. I am want it to look good.
~Rest In Peace~
paper filters i need to change to k&n filters this spring
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#9 | |
It's Better With Nitro
That master cylinder is a Mopar type.
I run a 7" cowl hood on my Chevy II Super Gas car and I have a air bell with an air pan that seals against the hood: ![]() Here's the one I fabricated for a friend who's engine was mounted at stock height: ![]() Here's what I'm building for the C-10: ![]()
Yup,, from Jeggie you can get it with the mounting kit for $89, or without for $69
http://www.jegs.com/i/JEGS-Performan...31403/10002/-1 Fittings to go to -an and brainded over teflon lined flex lines from Speedway for cheap.
![]() Join Date: Jun 2006
Vin63 that last picture is of the NASCAR style isn't it?
#13 |
Yes, including the Super Stocks of the 1963 Z11. I'm planning on using the inlet of the heater port in the cowl as the inlet for the air cleaner.
