12-26-2011, 11:31 PM | #1 |
cab mount bushings
maybe you guys can help a dummy. just opened a cab mount bushing set that i recieved with a truck purchase. it has two 3" bushings, two 2 1/2". two 1". two 3/4". then four what i believe to be bottom rubbers. and hardware which i believe is short 4 bolts. only 2 in kit. kit has no instructions with. getting ready to put front end on my gmc antrying to figure which ones to use. also cab is on truck already and has a 2" lift. im thinking i'll have to either find some 2" spacers or refab 2 1/2s. then use correct front mounts out of kit. anyone know what the correct front ones are? gonna try to load pics tomoro. any help appreciated, rich sorry such a long read.
12-27-2011, 12:48 AM | #2 |
Re: cab mount bushings
Bump ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-27-2011, 12:16 PM | #3 |
Junior Member
What year GMC? If I remember right the taller bushings are for the rear of the cab.
The front clip bushing size depends on the year of your truck. I don't have a picture of the instructions, sorry.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
12-27-2011, 01:08 PM | #4 |
Check out the pictures in Bruce88's build thread, and see if that helps you sort the parts out.
It’s Just A Pickup, Post #446 I recommend reading the entire build, it's amazing the amount of information provided. I use his thread for reference all the time.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-28-2011, 01:20 PM | #5 |
12-28-2011, 01:21 PM | #6 |
thanx for the help folks. rich
12-28-2011, 01:39 PM | #7 | |
12-28-2011, 03:23 PM | #8 |
SRV profile pic man too cool
12-28-2011, 05:29 PM | #9 |
12-28-2011, 05:31 PM | #10 |
12-28-2011, 06:25 PM | #11 |
Junior Member
Cab bushings are different from 1/2 T and 3/4 or 4wd. The rear cab mounts on a 3/4T and 4wd are lower on the frame than 1/2T 2wd to allow for a thicker rubber bushing to give a smoother cab ride.
12-29-2011, 03:17 AM | #12 |
maybe that is why there are so many. to cover all models.
