Old 12-26-2011, 11:55 PM   #1
Jarwood
Jarwood's Avatar
Rear Coil Spring height?
I need to pick your brains! I cut my front coils to get my height down to 29" from floor to center of my fender. I like the height for now in the front. I have not touched the rear but want my rear to be 29"-30". I do not want the rear of the truck to sit lower than the front. I need to buy rear coils. Here is the million dollar question. What size rear drop coils do I need to buy to get my truck at 29"-30" from floor to middle of fender? Ohyeah I have 20" wheels with 275/40 tires.
Thanks!
Jarwood is offline   Reply With Quote
Old 12-28-2011, 11:47 PM   #2
Jarwood
Jarwood's Avatar
Re: Rear Coil Spring height?
Any help? I am thinking a 4" lowered rear coil????
Old 12-29-2011, 12:04 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
What is your height now?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-29-2011, 12:11 AM   #4
Jarwood
Jarwood's Avatar
I am assuming they are stock springs...just wore out. If I measure from the floor to the middle or center of the rear quarter at the highest point is 32'' tall.
Old 12-29-2011, 12:18 AM   #5
Jarwood
Jarwood's Avatar
I was told that a new stock coil will lift the truck dramatically...I would like to stay around 30''..I have two sets of lowering blocks if needed, so if I can get new coils in and put the truck around the 30'' mark would be great.
Old 12-30-2011, 03:44 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
How much lower do you want it from where it is now? I would look into blocks and keeping your current springs if you're needing 3" of drop or less. They don't sell 3" blocks, but you could get a set of 1" and a set of 2". There's even a good thread on the board on how to make your own 2" blocks on the cheap.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-30-2011, 04:45 PM   #7
Jarwood
Jarwood's Avatar
Yeah I was thinking about just doing that. The only problem is I want the rear end height to match. Dont like one side being 31'' and the other 32''. I guess I could make the difference up in lowering blocks. I would like it to be around 30", which is 1 " higher than the front.
Thanks for the reply.
Old 12-31-2011, 11:10 AM   #8
cdowns
cdowns's Avatar
that would b a good way to have serious problems
Old 12-31-2011, 08:42 PM   #9
Jarwood
Jarwood's Avatar
what do you suggest. I am going to buy coils, but not sure what size to get...maybe 4" lowered springs and start there???
Old 01-01-2012, 11:36 AM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I got a set of U bolts for a 1" or 1.5" drop block, but no block lmk if interested.
Ece makes drop springs as "big" as 3" dropped springs
John
1999 Toyota Tacoma 4x4
Old 01-01-2012, 11:18 PM   #11
Jarwood
Jarwood's Avatar
Just ordered new rear coils 4" lowered, front and rear sway bars, and the deluxe trac bar from CPP.
Thanks for the help guys!
Old 01-02-2012, 05:09 PM   #12
oldblue1968chevy
Keep us posted on how you like the REAR sway bars.
The front bar is a HUGE upgrade, a must do for these trucks
John
