Old 04-23-2003, 03:40 PM   #1
stknrdr2
Temp Sender for Vortec heads
I recently installed some vortec heads, (they run sweetly by the way) and I need to know what temp sender to use.....
I read on here early volvo but I cant seem to find any more info than that..does anyone have the specific year/model 'o volvo? Or perhaps (gasp) a part number? I cant stand to drive around temp gaugeless much longer...good thing my cooling system is all new and trusted heheh
Boyd Johnson
STKNRDR
72 LWB c/10 4wd-Hugger Orange - Frame Off Resto, 350, 4"lift, Auburn Limited Slips Both Axles- 4.56 gears- 35's - HEI - Edelbrock Performer Carb and Intake.
Recently Completed - 700r4/NP208 conversion and vortec heads.
Future Goals - Vortec Injection, lowering back to original height, and one ton running gear so's I can haul all my crap. Lifted truck look cool but they are useless for anything but 'wheeling
stknrdr2 is offline   Reply With Quote
Old 04-23-2003, 06:59 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
I just ended up putting the original sender in the intake for now...I'm going to have to do something, though, even though I clearanced it I think it's slowly wearing through the upper radiator hose.
I'll need either a different way to route the top hose, or a different sender or place to put one...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-23-2003, 07:39 PM   #3
mikep
Used to have a truck
mikep's Avatar
Early 70's volvo. Up to 72 I believe .The have an AN type threading so the threads arent tapered. That just means you'll need a gasket. I got a nylon flat washer type gasket from the hardware store when I put one in my SR's which have the same size sender hole as the vortecs. If you are using a 180 degree thermostat it will put the needle straight up at 180. Its the only sender calibrated to do that with the type of gage we have in our trucks.
No truck :-(
mikep is offline   Reply With Quote
Old 04-24-2003, 02:01 AM   #4
alta-aj
I had an original machined.
I'm expecting the vortec heads have 3/8s NPT tread and that's the concern.
I have a 79 400 in my Jimmy and found that the temp sender from the 79 engine was the wrong resistance for the 72 gauge. So I went to NAPA and spent a good 15 minutes going through their books but could not find a temp sender with a 3/8s NPT of the same resistance as the old one.
Solution: I took a 72 vintage sender to a machine shop and had them cut the treads down - temp gauge works again!!
alta-aj is offline   Reply With Quote
Old 04-24-2003, 11:03 AM   #5
mikep
mikep's Avatar
Once again the volvo sensor is the correct resistance for a 180 degree thermostat. The threads on the volvo sensor are 3/8" straight which only means you'll need a gasket if you use one in a 3/8" pipe hole like in the vortecs
No truck :-(
