Old 12-27-2011, 05:43 PM   #1
cochino12
It followed me home?
cochino12's Avatar
will the weight of a 454 drop front end more?
Will the added weight of a 454/th400 combo cause the front end to sag more? I need to order some new drop springs and want to make sure I don't. Go too low. Thanks
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-27-2011, 05:58 PM   #2
burb1085
burb1085's Avatar
Re: will the weight of a 454 drop front end more?
I know that a big block calls for a coil different spring when ordering. Probably is a bit thicker/more heavy duty. If I'm not mistaken, a b.b. is 750 lbs approx. 250 lbs heavier than a s.b.
burb1085 is offline   Reply With Quote
Old 12-27-2011, 06:50 PM   #3
john_p
yes, a little over an inch depending on the springs you have now,, find a fat girl and have her sit on the hood... southern engineering
john_p is offline   Reply With Quote
Old 12-27-2011, 06:58 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
My friends half ton lowered about half to an inch with the stock springs. What you should be more concerned about is if you don't have a sway bar. A big block makes the sway a lot worse
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-27-2011, 07:07 PM   #5
muthstryker
muthstryker's Avatar
Just get one of your friends who is on the heavier side to step on the front bumper. Should give you an idea. LOL 2 smaller guys would work as well.
Matt
muthstryker is offline   Reply With Quote
Old 12-29-2011, 03:57 PM   #6
parrisc19844x4_468
parrisc19844x4_468's Avatar
Adam
C10 ? I swapped a 305 for 454 and no difference in my K15
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 12-31-2011, 11:48 PM   #7
1LowToy
Are we going to have a Fatguy hood oniment to see if a larger sway bar is need too?
1LowToy is offline   Reply With Quote
