Old 12-27-2011, 07:24 PM   #1
Hazieview
Building Dreams out of Dimes!
Modified Engine Wiring Schematic. Will it work?
Hey guys through numerous posts and help from fellow members I took a little time to modify an engine schematic for my application. I have a bran new engine wiring harness that has a few extra unused wires that I would like to get rid of. Would you guys please review my specs of my truck as well as the new engine schematic that I have color coded?
The schematic will be for:
1981 Chevy Shortbed
SB400
-One wire alternator
-Edelbrock carb (electric choke)
-High torque mini starter
My Schematic for my stock replacement modified engine harness:
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 12-27-2011, 07:37 PM   #2
Hazieview
Re: Modified Engine Wiring Schematic. Will it work?
I do question the green wire. It says the green wire is going to a Temp switch. Is this the same as the Temperature sending unit?
SB400 350th
Old 12-28-2011, 02:06 AM   #3
hatzie
Moderator
hatzie's Avatar
Everything looks good.
You might want to leave yourself a TACH wire that's already neatly bundled into the harness. A big hairy frame to block ground around the motor mounts never hurts either.
Old 12-28-2011, 08:23 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
for sure looks much nicer wrapped up
for that matter if you are going to add any extra lights,alarms that would be good too
could the green wire end, be showing both the gauge and idiot,switches?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-28-2011, 10:31 AM   #5
Hazieview
I am definetly going to run a flat braided ground from the block to the frame.
Thanks for the heads up on the tach wire too I almost forgot. I'll throw it in the harness too.
I'm still not sure about that green wire. I mean I could just hook it up to the gauge right?
Everything else looks ok though right? Just don't want to burn down my truck or hack up my bran new harness for nothing.
Thanks fellas!
SB400 350th
Old 12-28-2011, 12:33 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
In my pics it has both the gauge/switch @the oil and temp
arrow being gauge,flat being switch
I'd use it looks right ,but are the other wires in right?
Granted the spots in the plug change,and you may have simply moved them
just posting what i used, it shows 30&31 in different spots?
did you have gauges before? I was idiots
John
Old 12-28-2011, 01:49 PM   #7
Hazieview
That's because I think you use the wiring harness for the 1977-1980 chevy v8. I used the 81-87 chevy v8 schematic. CLICK HERE if you would like to download a copy.
(You may have to save it to your computer in order to zoom in. I dont know how to make the picture bigger.)
SB400 350th
Old 12-28-2011, 04:37 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
ok makes sense mine were here
http://forum.73-87chevytrucks.com/sm...c,11766.0.html
John
Old 12-29-2011, 12:02 AM   #9
hatzie
Moderator
hatzie's Avatar
Yup. The GM schematics show both Temp sender types on the end of Circuit #35 green wire because the connector is the same. Make sure you have the right temp sender for your cluster.
