NOS versus repro fenders, how to tell the difference
How can I tell NOS 60-66 fenders from GM reproduction fenders? I have a chance to buy a set of fenders locally and the seller is stating they are NOS but before I lay out the cash I want to make sure they are the real deal.
There was a posting in the classified section a few months back for some NOS 60-66 fenders and the differences between NOS and repros were discussed in that post but I can't seem find it now. Thanks.
Ken B ![]() 60 Chevy Apache 08 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. ![]() Just because something can be done doesn't mean it should be done... |
Enjoy your truck
Re: NOS versus repro fenders, how to tell the difference
There should be a 2 digit year stamped into the top rail (the area that bolts to the inner fender) of the fender if it is oem.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
#3 | |
![]() Join Date: Jul 2009
Original fenders are easy to spot. They have either large rust holes or a pound of Bondo in the lower rear corners...........
Haha....I like this answer best
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I went and looked at those 60-66 NOS fenders today and they weren't. Even though they had GM stickers with part numbers they were definitely reproductions. The inner bracing was a thinner gauge steel than what GM used and the shape of the bracing was noticeable different at the bottom of the fender. Glad I didn't lay out $650 for $400 worth of offshore made fenders.
X3 Aint it the truth! I have also noticed the repro's being thinner too. Good luck. I'd be looking for a set with rust and then a welder.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
