12-27-2011, 10:36 PM | #1 |
Another newb motor mount question
Can someone help me find a thread or some plans for V8 conversion in 4.3 s-10 frame??? Or the best way to mount it in my 54/s10. Thanks in advance
12-28-2011, 09:39 AM | #2 |
and a few others
Re: Another newb motor mount question
I know nobody wants to hear: "use the search function" so I won't do that to you, but looking at this page:
http://67-72chevytrucks.com/vboard/f...splay.php?f=13 near the top is the "Projects and Builds" sub-category. Scroll through the posts there and you'll see it's pretty easy to pick out who's doing S-10 swaps. You'll also see that there's no one answer to you question. It's been done several different ways. I'm sure you'll see a method that will work for you.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
12-28-2011, 02:12 PM | #3 |
Yeah I used the search and just about everything came up. Just was seeing if anybody had a good plan or method for it. I'll figure it out. Thanks tho
Posted via Mobile Device |
12-28-2011, 04:04 PM | #4 |
Bowtie is right, depends on your skill level. some like to figure it out and fab everything. others will buy a kit someelse has done. Look at sgtusmc build, turned out really nice and he did all the fab work himself.
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-28-2011, 05:53 PM | #5 |
I fab all my own stuff but I was just wanting to look at different ideas and whats worked best or if there was a quicker route. Thanks
01-01-2012, 10:23 AM | #6 |
and a few others
I'm going with the method xpickup used on his 54.
S-10 swap mounts with the original 2436 motor mounts. Basically, turn everything upside-down. The metal conversion mounts are used on the opposite side that they were made for. And you mount the 2436 rubber mounts directly to the engine block like a pre-69 Camaro. Then weld the S-10 bracket onto your K member. This is xpickup's mounts: and mine ready to go in:
01-01-2012, 11:48 AM | #7 |
Thank you, that seems pretty quick and easy like I need. That's the 2.8 rubber mount?
01-02-2012, 08:51 PM | #8 |
This is the way I'm doing mine...
01-02-2012, 09:02 PM | #9 |
Thanks AD, that looks exactly what I came up with first. I just used 1/8 plate just to see how it would be. Need to go get thicker plate and finalize it
01-02-2012, 09:12 PM | #10 |
Mine are 5"x8" 1/2" plate. drilled to the factory 4.3 locations using the back hole to mount the front hole in the frame mount. I need to drill and tap the back ones. Then regular 4.3 mounts will bolt to the small block and drop straight on the frame mounts.
01-03-2012, 01:33 PM | #11 |
Here are a few pics of mine sittin in the factory 4.3 location.
01-03-2012, 01:44 PM | #12 | |
Shannon |
