Vintage 4x4s
Valve Cover Emissions Sticker
Anyone know of a company making reproduction valve cover date stickers? This is on my 72 350 and is aluminum based, not paper or plastic.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
![]() Join Date: Feb 2011
Re: Valve Cover Emissions Sticker
I've not seen those around. What year did they begin and /or end? Also under "Family" it says GM...would'nt they all say GM or is there something else stamped next to that?
Curious too...
MusicMan70 1961 GMC Suburban |
Vintage 4x4s
Yes, they'd all say GM but the stamping would vary depending on configuration. After the GM, it says 113 which is stamped in. I suppose 113 is code for 4bbl, that compression ratio, etc but I'm not positive since the block stamp has that info as well.
Florida Edition
![]() ![]() Join Date: Oct 2010
I have the same one on my 72 GMC, have not seen one on any earlier engines so it might be a 72 and up thing. Have not seen anybody re-poping them either, sorry.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Vintage 4x4s
ttt still looking. Maybe I'll check with some corvette guys?
