Old 12-28-2011, 02:07 AM   #1
Livrat
Member #1049
Livrat's Avatar
4X4 dip stick differences
Ran across another mystery, I am familar with the bottom two dipsticks pictured which are the usual ones that I find in our V8 4X4's..
Look at the top one, it had a different mount and curve to the tube, it bolts on in the same place and ends up at the same location as the top two but the curve is way different. Does anyone know what the application is for it?? was there more than one style?
Livrat is offline   Reply With Quote
Old 12-28-2011, 02:16 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 4X4 dip stick differences
Just a guess, power or manual brakes?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-28-2011, 08:24 AM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Odd that you posted this question. Going through my "junk" and looking for a extra dipstick/tube setup. I have the bottom type also. I was complaring it, as you are and cannot come up with an exact fit. My thoughts are it might be a BB application or another brand that GM used. Or, last - not even GM. The person that I think would know is Jerry Moss. I'll get in touch with him.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 12-28-2011, 10:31 AM   #4
CG
BlahBlahBlah
I had a similar one in a 4x4 years ago and was told by the previous owner it was out of a van.
Old 12-28-2011, 11:00 AM   #5
JimKshortstep4x4
I don't believe that the third dipstick is from a big block as the dipsticks on the big blocks are on the passenger side of the engine.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-28-2011, 12:27 PM   #6
Livrat
Member #1049
Livrat's Avatar
I think the van ones are much longer, I know it is not for a big block (tried it) its totally baasackwards.
It fits perfectly and bolts up like its made for a drivers small block configuration. Does anyone have a parts book for 69-72 to see if there was a difference in 4X4's from manual to power brakes?
Old 12-28-2011, 12:51 PM   #7
68panelman
68panelman's Avatar
My 70' blazer has manual brakes, v8. The bottom two are the same as mine. Original engine also.
68panelman is offline   Reply With Quote
Old 12-28-2011, 01:14 PM   #8
BurnoutNova
BurnoutNova's Avatar
I wonder if a K10/20 with an I6 would have a similar dipstick?
I need to find one of these for my K10, my tube broke and I don't have the correct one now.
BurnoutNova is offline   Reply With Quote
Old 12-28-2011, 08:07 PM   #9
71 super
71 super's Avatar
The six is on passenger side and no different from 2wd 6. Both of my 72 4x4's have the deep curved unit but one with a little lift would make getting stuff back in the hole easier, maybe it was bent?
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-28-2011, 09:28 PM   #10
southern parts
southern parts's Avatar
i`m almost sure both my 67`s have that dipstick. maybe a 67 only type
southern parts is offline   Reply With Quote
