Old 12-28-2011, 05:35 PM   #1
banno
banno's Avatar
bench seat question
Hello all,
I could buy this bench seat. The owner told me, that it comes from a 1974 C10 or C20.
Will it fit into my 1965 C10 ? What are the differences between the above mentioned manufacturing years? Is it possible to put a 1965 bench seat cover on it (after some modification)?
Thanks in advance
Best greetings from Germany
Martin
banno is offline   Reply With Quote
Old 12-28-2011, 06:14 PM   #2
jimmydean
jimmydean's Avatar
Re: bench seat question
The mounting might be different, but easy enough to modify I'm sure. I bolted a '85 split bench in my '69 and only had to drill new holes for the middle. not sure on the cover, but I think they are similar enough to make work.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-29-2011, 12:00 AM   #3
rbar
rbar's Avatar
I had an 89 or 90 bench in my 65. It only had to have different holes drilled, but I didn't have to have any different kind of mounting. I fit nice and I liked it at the time.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 12-29-2011, 09:19 AM   #4
1963c-10
1963c-10's Avatar
Looks like the rear seat cover on that bench covers the hinges, which the 65 seat cover will not. Im sure that something could be done...might be easier to take the new cover and seat to the upholstery shop for the mods.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-29-2011, 01:46 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
That seat looks more like it came from a 76-77, not that it matters.
I would think the only issue you would have with putting on the 60-66 seat cover, besides not covering the hinges as mentioned above, is that the tops of the 60-66 seats are much more rounded. That might give you a hang up also when trying to install it.
