Old 12-28-2011, 11:32 PM   #1
bradley7576
BRAKES!!!!!!:drama:
im stuck!!! new MC new front wheel cyclinders and no pedal...the back brakes are great!! just the front drums somethings wrong!!!!!!!!
bradley7576 is offline   Reply With Quote
Old 12-28-2011, 11:43 PM   #2
pat 70/71
pat 70/71's Avatar
Re: BRAKES!!!!!!:drama:
Did you bench bleed the master prior to install? New wheel cylinders on the front, Did you change out the rubber hoses? If you did just open the wheel cylinders ( one at a time and pump the schmitt out of the pedal) should push some fluid. I have had this same issue and in my case it was a bad master! (and it was brand new) cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 12-28-2011, 11:52 PM   #3
bradley7576
yeah i bled the master first....i think i have a leak somewhere but i cant find it
Old 12-29-2011, 12:01 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Are the shoes Adjusted up?
Old 12-29-2011, 12:18 AM   #5
bradley7576
yryruyruryruytruyruyruyriufghfhfffhvvbxbnjgit78568696986i869989699o9uyyyyho9y90979797989789o87oiuiui uikkkhjkhhlkhollglkhkhkhgkhkhkhkhkhkhkhkhkhkhkhkhkhkhkkhkhkhkhkhkhkhkhkhkhhooy6989896899iiyohiyoyi7i 67i798uu9yo9ui9uo09ipuiui57opi8r76t7r8tr847t44098t9084ituiyt7g8yh48yr85tihtuirethwrourogureuigujvhuh uirhrughvhgggggggggggggggggggggggggggggggggggggggggg7g7hg77h5gg5h7h7g5h7g5h75gh5gh7h75gng751t985t498 ut589u4905t8689u6tu8tjmgbgbjguyhyh9u86yu6y9uii6tutu9ttgt5g9u5tutu9t65u6u96i6t598u6t5u986t5u6t658u956 t489u6t89u6y5u6y5u6t589u65t98u689u6598u6589u76yutguytu6y5uy66u6u6tuututututu5tutrujunhhhhhh445567801 24689089899858758875898757858758974749749873897878974489747634289734987348oooooobbbvvffffhkgghggtygg bnhjjh
Old 12-29-2011, 01:05 AM   #6
68gmsee
Active Member
68gmsee's Avatar
68gmsee is offline   Reply With Quote
Old 12-29-2011, 03:30 AM   #7
bradley7576
sorry i left this up and my 5 yr old wanted to put in her 2cents worth....i think its an algarythem.
Old 12-29-2011, 11:58 AM   #8
CC69Rat
CC69Rat's Avatar
Did you re-fill the Master with fluid as you bled off the lines? Did it just run out of fluid maybe ?
If you open the bleeders .. pump the pedal, any fluid (As stated above) ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
