Please decode Vin
I need some help to decode my vin CE241J639657. Does it tell you if it is a 350? Is this a 3/4 ton? Thanks for your help.
Posted via Mobile Device |
Vintage 4x4s
Re: Please decode Vin
Your truck is a 2wd, v8, 3/4 ton, 1971 made in Janesville, WI. No way to know just off vin whether or not it came with 307, 350, or 402.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Here is some more info on my truck. It is badged says it is a ct10 the wheels are five luge not six. Were there 5 luge 3/4 ton or has someone changed it to a 1/2 ton? How can I tell if it is a 1/2 or 3/4 ton?
Florida Edition
![]() ![]() Join Date: Oct 2010
Here is a link to LMC VIN decoder http://www.lmctruck.com/icatalog/cb/full.aspx?Page=9
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Roadtrip!
![]() Join Date: Feb 2003
All of the 71-72 1/2 ton 2wd trucks were 5 lug. 67-70 and 1/2 ton 4x4 were 6 lug. All 3/4 ton are 8 lug. Double check your VIN with the title and the glove box door and make sure they are the same.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Florida Edition
Old Skool Club
![]() Join Date: Jun 2001
Based on the VIN, the first response to your question is right. But, based on what you say is on the fender (C10) and the 5-lug wheel pattern, makes me wonder if the cab is original to the chassis. I'm guessing that the cab VIN matches your title.
Look on the chassis on the driver's side, in front of the firewall and there will be numbers stamped into the top of the frame rail. If it matches the numbers on your VIN tag, then someone has done some "work" on the chassis. If it doesn't match, it sounds like your cab was placed on the chassis you have. You have some detective work to do.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I did check the vin on the frame it does match the vin on the glove box,frame,title. But the title says it is a 1/2 ton. I am the second owner so I guess the previous owner had changed some suspension parts? Or could this have been a production screw up?
