Old 12-29-2011, 03:46 AM   #1
Bad70sbchevy
Bad70sbchevy's Avatar
Question Power Steering Rebuild Question
Hey guys I'm in the middle of rebuilding the power steering box on my 1970 c10 and I noticed that the ball bearings are all the same color (or appear to be). I always heard that they are suppose to be two different colors and you alternate them. Are our boxes different and the bearings all the same size? Thanks again in advance.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 12-29-2011, 10:54 AM   #2
JimKshortstep4x4
Re: Power Steering Rebuild Question
There should be two ball sizes. The smaller ball is used as a spacer between the load carring balls. I would suggest using a micrometer to check the balls for size. You will want to put smaller balls in between the larger balls as without the spacer balls some binding can develope.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-30-2011, 02:06 AM   #3
Bad70sbchevy
Thanks I was just curious. Ended up separating the bearing by shining a halogen light on them (still had a gold tarnish to them). Guess the dye wears off after 40 years.
