12-29-2011, 10:36 AM | #1 |
Brake line size?
Getting ready to build some new stainless brake lines and was wondering what size of tubing to use. Is it 3/16 on the 72? Also anyone use the AN fittings and how did they work for you? Also if I convert to rear disc can I use the factory diameter brake tubing?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
12-29-2011, 10:49 AM | #2 |
Re: Brake line size?
Stock brake lines on a 72 are 3/16" front, (master cylinder to the caliper hoses), 1/4" rear (from the master cylinder to a connection to a hose at the rear end location). On the rear axle the hose connects to a tee and from the tee to the brake cylinders, 3/16" line is used.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-29-2011, 11:29 AM | #3 |
Thank you very much!
01-04-2012, 09:10 PM | #4 |
Is there harm in building my back lines in 3/16? I read the other day that guys with rear discs sometimes have to rebuild their back lines down to 3/16 but will this push drums adequately?
06-14-2012, 02:36 PM | #5 |
Interesting thread man. I was just looking for answers for the same questions. One thing I noticed on my new parts is that the rear wheel cylinders take different size fittings and the rear hose that splits to the cylenders are both the same size. What's up with that?
Posted via Mobile Device |
