Is this possible?
My 67 Lwb has a 292 straight 6 and a 5 speed trans. The cab has a low hump, is it possible to put an automatic transmission in it? I like my 5 speed trans but due to a bad back, it's getting harder to drive.
If possible, what would be a good hook up and what would I need to make the change? Thank you all for your help.
"Arrive, Raise Hell, Create Confusion, Leave". |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Is this possible?
No problem with the low hump, high hump was only big blocks and 4x4's. I'll let others tell you about the swap as all mine are auto. Good luck and happy new year!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
I have a 2x2 3/4 ton 305 4spd with high hump that is bolted in to floor pan. my 68 292 3spd has small hump that is part of floor pan not bolted in like high hump.
Old Skool Club
![]() Join Date: Jun 2001
My 2WD 350/TH400 has a small hump.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Thanks for the information. I truly appreciate it. I look forward to hearing from those who have made the swaps. Also, I enjoyed the "Cheap Tricks" link you posted. Don't know if I can still subscribe to this but if I can, let me know how. Thank you again.
#6 | |
Florida Edition
its all about the +6 inches
A th400 or th350 will fit in there fine. The high humps were for 4x4 trucks, 4 speeds, and big blocks with Anything but a 3 speed.
Posted via Mobile Device |
Lemme show you something!!
Any Hydromatic tranny should bolt right up. TH350 and 400 are probably the simplest to install, but lack an overdrive. The 700-R4 is very popular and the 200-4r is a good option too if you want/need overdrive. Beyond that you'll need to buy or fab up a cross member for the tranny of choice, source a radiator with the cooler provisions or run a secondary trans cooler. You'll also need to either swap the column for a unit with the automatic linkage or get a floor mount shifter. New carb linkage and driveline swap may also be neccessary. Furthermore you'll need to either tear apart your pedal assembly and remove the clutch pedal or get a pedal assembly for an automatic truck, remove your clutch linkage and find a fill plug for the hole in the firewall.
Let me know if you decide to do this- I have the pedal assembly, radiator and column if you need them, that I would possibly trade for the 5-speed you have.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
#9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=489394 click on the link and when it comes up look for the thread tools along the blueline just above the first post. click on this and it asks if you want to subscribe-click on that and follow the instructions. you can do this on any thread you like on here and never loose track of them again also you can get replies e-mailed to you as often as you like by clicking on the different options. hope this helps-cheers
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
#10 | |
Don't worry about the pedals. The assemblies are the same between auto and manual. The clutch pedal slides off the end. Its obvious when you look at it. After I did the swap it took about a year to stop trying to push the missing clutch pedal at start up and at stop signs. ![]() Posted via Mobile Device
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I did the exact swap on my old 67. Event went and swapped out the straight 6 for a built small block. Did it all on my back in my dad's driveway with hand tools. Not near as bad as it may seem...
05 QSM GTO - M6, Corsa, King Springs 70 SWB CST - 350/Auto, Foose 18/17 I upset whiners too.... |
