Old 12-29-2011, 02:41 PM   #1
MTBADBOB
Dust Shield Staples Help
Hello,
I was wondering if anyone had any tricks or tips for replacing those factory staples used on radiatior & hood dust shields???? I know they are tought to try to straighten, and I've even heard of people having the staple guns used to install them. Any help would be greatly appreciated! Thanks...Bob
MTBADBOB is offline   Reply With Quote
Old 12-29-2011, 03:30 PM   #2
1963c-10
1963c-10's Avatar
Re: Dust Shield Staples Help
When I did mine, I use stainless staples for a staple gun and used needle nose pliers to bend them. They come in alot of different sizes, just take an old one and find the proper size. I believe the same can be done with front fender seals also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-29-2011, 06:25 PM   #3
slorio
slorio's Avatar
MTBadBob:
Take a look here and you can see what I used:
http://67-72chevytrucks.com/vboard/s...57#post4310757
regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 12-29-2011, 07:21 PM   #4
Heater63
Heater63's Avatar
It depends on how original you want them to look. For a correct restoration look it is best, but tedious, to cut and bend them by hand using heavy wire (piano wire)
292 + TKO500
Heater63 is offline   Reply With Quote
Old 12-29-2011, 09:37 PM   #5
MTBADBOB
Thanks for all the info & help. I have a lead on a guy who is supposed to have one of those GM staple guns too. I was also told by a guy to use galv. wire & bend it w/needle nose & crimp open ends with vise grip to give it that factory stapled look.
