Bench seat question
I have a 1971 Chev truck and want to replace the buckets and console with a bench. Do I have to stay with a 67 to 72 bench or will the mid to late 70's seats bolt right in?
the late 80's early 90's split bench works very well.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Do they bolt right in?
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
its all about the +6 inches
Just so no one rips you off...or even worse, so you don't throw them away, the buckets and console are worth quite a bit of coin.
I have a mid-90s Silverado bench in my 68. It does NOT bolt right in. But all I had to do was drill 4 holes in the flat area under the stock bench. It is a very comfortable seat, especially on long trips. The newer seats are solid foam - no springs - and therefor give much better support. Purists won't like my answer, but to each his own. Try different seats before you choose one.
The stock buckets and console are worth some bucks to someone doing a resto. Good luck. Scott
Silence is golden, duct tape is silver. - Scott |
Long horn mail thanks I do know the value of what I am taking out of the truck and they'll be tucked away in the basement for later. Right now I need the truck to seat myself and 2 blondes.
14.1 @ 96MPH
I've got a 1999 Suburban middle seat; had to drill most of the holes and cut on the stock brackets a little bit, but I think it's one of the best deals going - I got mine for $150. Part of the center seatback folds down to be the center console.
Project1970 - LS1 Swap Complete! ![]() |
![]() Join Date: Apr 2003
I have a 94 60/40 split bench seat in my 72, Had to drill holes, but the brackets almost fit perfect, had to build a spacer for the inside bracket of the passenger side 60 seat. They look really good, mainly because of the headrests.
good luck
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
2 blondes eh??? is that your wife and your daughter
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
seat for sale
I've got a 60/40 split bench seat for sale with the fold down middle armrest that you can put things in. grey in color and in perfect condition. it's the 95-99 style that doesn't have the seat belts built inot them.
