Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-29-2011, 10:23 PM   #1
Ratman1956
Factory speaker sizes?
Hello All,
I recently purchased a 1986 Silverado SB 2WD. It has what appears to be factory rear speakers (both sides) and three front (dash) speakers. My wife purchased me the Retro Sound model #8573 stereo from LMC for Christmas. I would like to replace the speakers at the same time that I install the stereo. What size are the factory speakers and does anyone have a suggestion for what to replace them with?
Thanks in advance for your input,
Ratman
Ratman1956 is offline   Reply With Quote
Old 12-29-2011, 10:47 PM   #2
WAAF
Re: Factory speaker sizes?
dash is 3 1/4" round
behind seat is 4x10"
WAAF is offline   Reply With Quote
Old 12-29-2011, 10:50 PM   #3
Ratman1956
Is the center dash speaker a 4x10 also?
Old 12-29-2011, 10:52 PM   #4
WAAF
http://www.crutchfield.com/p_065SE35...35.html?tp=105
front
http://www.crutchfield.com/p_113KFC4...ml?tp=99&avf=N
rear
fyi late 90's early 2000's cattys have bose or infinity 4x10's .. might be worth a trip to junk yard.. if looking on a cheap good 4x10 fronts .. nothing stock is all that good..lol
Old 12-29-2011, 11:01 PM   #5
Ratman1956
So are you saying that the center dash speaker is not used?
P.S. Thanks for your help!
Old 12-29-2011, 11:16 PM   #6
WAAF
no, skip it.. unless your running a mono am radio..
Old 12-29-2011, 11:18 PM   #7
Ratman1956
Cool, thanks!
Old 12-30-2011, 01:34 PM   #8
jimmydean
jimmydean's Avatar
you could wire a center speaker in series (mono) off of the front channels if the deck has 4 channels. That would give you a center stage, or you could not use it. I am using 2 3.5" 2-ways in the center of my '66. But I like having a center stage.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-21-2012, 12:37 PM   #9
Ratman1956
Can the dash speakers be mounted by removing the dash pad or do they need to be installed from under the dash?
Old 01-22-2012, 02:52 PM   #10
stroker87
yes you need to remove the dash pad to mount them they drop in from the top, be careful not to hit the windshield with the socket or wrench my cousin did when the socket slipped and cracked his
stroker87 is offline   Reply With Quote
Old 01-22-2012, 09:19 PM   #11
Ratman1956
Thanks, that's what I was hoping to hear and I appreciate the heads-up!
Old 01-24-2012, 05:43 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
there is a bracket (holding the speaker to the hole)if you can eliminate it you should be able to get a bigger speaker in there...
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-11-2012, 09:58 PM   #13
Ratman1956
[QUOTE=WAAF;5090356]http://www.crutchfield.com/p_065SE35...35.html?tp=105
front
rear
Bought these and finally got around to installing them this weekend. Just an FYI these 4x10's are much deeper than the factory ones and I had to make spacers to give them enough room for the additional depth.
