Old 12-29-2011, 10:42 PM   #1
Mieser3
Mieser3's Avatar
Which Master Cylinder Bore Size?
Looking to purchase my Wilwood master cylinder and Wilwood proportioning valve so that I can finally finish up my brake system but I'm unclear on which bore size I need. I am running Wilwood D52 dual piston calipers front and back with 3/16" stainless steel brake lines. I plan on getting this proportioning valve:
http://www.wilwood.com/MasterCylinde...emno=260-11179
I will be getting this master cylinder:
http://www.wilwood.com/MasterCylinde...mno=260-8555-P
There are 3 different bore sizes available: 7/8", 1" or 1 1/8". Which bore size do I need for my application?
Thanks!
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 12-29-2011, 10:54 PM   #2
edhtrd71
Re: Which Master Cylinder Bore Size?
I think the stock size is 1 1/16. I wish I could help recomend which one. You could call wilwood. 1 inch will give more pressure less volume, 1 1/8 will give more volume less pressure. I hope someone chimes in, im interested to know which aluminum master will work well also.
edhtrd71 is offline   Reply With Quote
Old 12-29-2011, 10:57 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm going to use the 1" bore without a booster on my stepside.
3/16" brake lines also.
Keith
Convert to disc brakes.
Old 12-29-2011, 11:04 PM   #4
Mieser3
Mieser3's Avatar
I forgot to mention that I'll also be running an 8" dual diaphragm booster as well.
Interested to see what is recommended......
Jay
1970 Camaro Z-28/RS
Old 12-29-2011, 11:24 PM   #5
kpeztruck
kpeztruck's Avatar
I highly recommend calling the tech dept at Wilwood. That is what I did years ago on my build, and they pointed me in the right direction. Paul
kpeztruck is offline   Reply With Quote
Old 12-30-2011, 01:29 PM   #6
Mieser3
Mieser3's Avatar
I spoke to the tech dept. at Wilwood and they told me to use the 1 1/8" bore for my setup. Just thought you guys might be interested in their recommendation.
Jay
1970 Camaro Z-28/RS
Old 12-30-2011, 01:34 PM   #7
Scottshotrods
1 1/8 bore is what we have been useing on wilwood master and this is with out a booster and it works great with wilwood d52 this way.
So you know we have these instock and have some great prices on them !!!
Justin
Scottshotrods is offline   Reply With Quote
Old 03-07-2012, 10:10 PM   #8
RdoubleU
RdoubleU's Avatar
Jay / Keith - can you give any detail into what you had to do with the brake pedal pushrod with these MC?
Wilwood stated the 7/8 MC came with a new pushrod but the 1 and 1 1/8" bores did not.
Does the factory pushrod work with no issues?
RdoubleU is offline   Reply With Quote
Old 03-07-2012, 10:45 PM   #9
lolife99
lolife99's Avatar
My master cylinder push rod worked fine.
You want between 1/8" and 1/4" freeplay in the pedal pushrod.
Keith
Old 03-07-2012, 10:54 PM   #10
RdoubleU
RdoubleU's Avatar
Thanks Keith, I'm going with the 1" manual setup as well so Good to know it worked for you
